Name: Robert Terry |
Has anyone experienced this? If I apply any kind of Raytrace map to a material and have the background turned on in the slot, the sample material becomes invisible no matter the settings, Only way to make is visible again is to copy a "None" map to replace raytrace. It has no affect on the material itself just the sample in the slot. I have a bunch of different materials with raytraced reflections but I can't easily identify which material is which in the M.E. because they all look like this: see attached. Any ideas or solutions?
Thanks, -=Rob |
Name: Eduardo Romero |
i'm not sure, but go to render dialog, raytracer tab, and check "enable raytracing", maybe you unchecked it inadvertedly.
if it's not that, i dunno what it could be... |
| Chrome material problem | evanmoses | VRay Render | 18 | March 16th, 2005 09:12 AM |
| how to put library material to scene material | oviam | Scripts | 0 | July 8th, 2004 02:10 PM |
| Logo with Blend material | Jape | 3ds Max | 3 | June 9th, 2004 09:27 AM |
| Assigning Material in VIZ5 | Wampa | Autodesk VIZ | 4 | May 24th, 2004 01:02 AM |
| Material Script | nisus | Scripts | 5 | July 8th, 2002 11:49 PM |
