Old April 4th, 2005   #11 (permalink)
Name: Andrew Schroeder
Default Re: How do you convert PDF to DWG??
PDF's published directly from Autocad are in vector format (provided you're not exporting raster images). So, converting from a PDF vector file to a raster and then performing raster to vector will comprimise the data. You're better off doing as you mentioned, bringing it into Illustrator and exporting to DWG/DXF.
All of that said, there's probably a reason the file is only available in PDF format. It's the protocol of many offices to only release drawings in PDF, since they believe it's 'secure', un-alterable, etc., rather than a drafter not wanting to share. These days, a lot of people are switching to DWF for that, but it'll be a while before that takes off. If you cannot contact the firm to get the original AutoCAD file, or you have and they won't give it to you, then you might want to think twice about using the file for your work. Not having seen it, the judgment is of course yours, but it's something to consider. A more curruent version may exist, there may be legal matters surrounding it's use, etc..
Schroeder is offline
Old April 6th, 2005   #12 (permalink)
Richard McCarthy's Avatar
Thanks guys for all your help!
I appreciated it.
Don't mess with my hat !!
Richard McCarthy is offline
convert 4:3 to 16:9 widescreen Jim Mann Compositing Software 7 April 15th, 2008 04:33 PM
maya dwg problems cat Maya 3 March 12th, 2005 05:32 PM
AUTOCAD dwg file convert to PDF file Chris Potts AutoCAD/AutoCAD Architecture 9 October 8th, 2004 01:42 AM
dwg to max6 problem alzain 3ds Max 12 September 4th, 2004 10:34 AM
EMERGENCY - AutoCAD --> PDF to scale.. mzagorski AutoCAD/AutoCAD Architecture 8 May 26th, 2003 02:47 AM
