| Photoshop Adobe Photoshop |
Name: Travis Rhoads |
Hello everyone. I have a problem with Photoshop 7. I just bought a copy on ebay, and upgraded from 6 to 7. When I open files, white is represented as yellow. (See attached screenshot) That drawing is supposed to be white, it is when opened in v.6, it is in Imageready 7.0, but not in Photoshop 7. Does anyone have any suggestions, It really sucks, because everything is too yellow now.
I am trying to drink away the part of the day that I can not sleep away.
Hi,
it seems that your ACO files are corrupted. They are found in the presets>color books and color swatches folder in photoshop root. Try the attached set of copies from my PS 7.0. Copy to the presets folder and overwrite. (only a couples of Kb's) Good luck, Dennis
__________________________________________ PRIESTERMEDIA 3D Visualisaties & Presentaties Rotterdam, the Netherlands Last edited by DennisHolland; April 5th, 2005 at 09:36 AM. |
Dennis,
I have uninstalled, 7.0, then 6.0, and Imageready. Then it was still displaying wrong. I tried your files, thank you for sharing, but still no luck. I just went in now and turned color management off, and that fixed it. But is that going to cause trouble in other ways?
Color management (mismanagement in this particular case:-) turned off doesn't affect your renderwork in a serious way. It is only a finetuning-tool and mostly used for printmedia and a bit of high-end website design.
Good luck, Dennis
__________________________________________ PRIESTERMEDIA 3D Visualisaties & Presentaties Rotterdam, the Netherlands |
Ok, thanks for the info, I will not worry about it then. Thanks for your help.
| Can't make material white enough! | JPS | Autodesk VIZ | 7 | March 24th, 2003 01:53 AM |
