| 3ds Max Autodesk 3ds Max |
Name: James Thomack |
Newbie question for everyone:
I have a contour model that I've modelled in AutoCAD. Each 2-foot increment of elevation is represented by an extruded polyline. I have imported the model into 3DS 7 so that each is a separate polymesh. My problem arises when I try to apply a material to these polymeshes, namely a grass material. I can see a change in the shaded color of the polymeshes and it renders as a darker green than otherwise, but there is no texture/map to it. If I draw a line shape next to it in 3DS and extrude that in 3DS, and render the exact same situation, the grass material renders on the new polymesh, but not those that I've imported. Does anyone know why this is happening? I tried to get around it by creating a new shape from my imported polymeshes, but I keep winding up with an outline consisting of planes in the Z-axis instead of a line that I can extrude...I'm out of ideas... |
Chad, that did the trick as soon as I flipped through my trusty quick-start manual and figured out how to do it. thanks for the assistance and quick reply!
| Chrome material problem | evanmoses | VRay Render | 18 | March 16th, 2005 09:12 AM |
| Merge and use scene material problem in Max7 | dimopoulos_d | 3ds Max | 5 | February 18th, 2005 10:02 AM |
| importing and uvw map applying autocad model in 3ds MAX | j.k | 3ds Max | 3 | May 13th, 2004 11:20 PM |
| material problem | carlos_ramiro | 3ds Max | 3 | February 12th, 2004 08:25 AM |
| Autocad to Illustrator problem!!! | Tony | AutoCAD/AutoCAD Architecture | 10 | October 28th, 2003 04:32 PM |
