| Autodesk VIZ Autodesk VIZ |
Name: Jason Matthews |
Hey everyone. I am doing a project using viz 2005 radiosity and i am getting some strange artifacts where two objects are joinging. I model in autocad and file link to viz. It is hapening in strange places as well. I am using daylight system and about 30 omni lights (photmetric). Here are some images showing this.
Solution quality: 85% Refinements vary between 10 to 25 Filtering: 3 Mesh varies Thanks in advance.
Jason Matthews |
Name: olaf lubanski |
do your walls join seemlessly?
have a look at the image, you should avoid connections like the second one, which will produce shadow- as well as light-leaks with a radiosity method. if you render with regather the leaks should be gone though. but rendering takes much longer. |
Name: Mark Woodard |
If you're using shadow map shadows, try uping the size from the default 512 to something bigger. Try putting a plane above your internals to help block out light leaks.
Hope that helps. |
Name: Jennifer O'Connor |
Yes, make sure your model is seamless, very important. You can also try enabling "Regather Indirect Illumination" to clean up artifacts. This can slow things up quite a bit at render time, as VIZ recalulates the indirect light for each pixel. This can help with scenes that are not subdivided to a high degree.
Jenni www.4DA-inc.com Chicago 3ds Max / Maya UG www.max3ds.com Render UG www.Render-Art.com |
| Price of V-Ray Stand Alone Version? | GaryR50 | VRay Render | 47 | 22 Hours Ago 01:36 PM |
| Radiosity network rendering | David | Autodesk VIZ | 1 | September 25th, 2003 01:15 AM |
| How to turn off Radiosity??? | Aaron | Autodesk VIZ | 3 | July 28th, 2003 12:34 PM |
| radiosity rendering time | trey | Autodesk VIZ | 0 | October 11th, 2002 03:27 AM |
