3ds Max Autodesk 3ds Max
Old April 6th, 2005   #1 (permalink)
Bugga_Guy's Avatar
Default copying object refferencing a line object
Hi,
I was wondering if anyone knows how to clone objects refferencing a line.. I know there is the path constraint, but is there anything else something easier that someone could help me with?
What I am trying to make is a pipe that has several bends with in it, and around that pipe are rings that on center of the pipe.
An help would greatly be appreciated!
Bugga_Guy is offline
Old April 6th, 2005   #2 (permalink)
Chad Warner's Avatar
Default Re: copying object refferencing a line object
How about the spacing tool? I haven't used it enough to know if it will work, but it would be worth a shot.
Chad Warner is offline
Old April 6th, 2005   #3 (permalink)
Bugga_Guy's Avatar
what spacing tool - sorry I am not aware of it. Can you explain how you would use it/where can I find it?
Old April 6th, 2005   #4 (permalink)
With Viz, it's under "tools" then "spacing tool". You pick the object you want to space out, then pick the path that you want to space the object along. There are options for "folow", distances, start and finish, etc.
Like I said, I haven't used it a whole lot, so I don't know if it will do what you want it to.
Old April 6th, 2005   #5 (permalink)
Bugga_Guy's Avatar
Chad, thank you, I did a search on the help menu about the spacing tool and it is exaclty what I need. Many thanks!!!
