Old April 6th, 2005   #1 (permalink)
Name: Anwar Fardullah
Singapore
Default Rendering Stainless Steel
i seem to have this problem of rendering a convincing stainless steel material in my scenes. i use the max's architectural materials and rendered using mental ray, but it turns out very dark grey.
i also have use a preset steel material, and still doesn't look like a brushed stainless steel. could it be with the materials setting?
mesht is offline
Old April 6th, 2005   #2 (permalink)
Tim Nelson's Avatar
Default Re: Rendering Stainless Steel
It could be either the settings or the reflection environment. Without anything to reflect, stainless steel will be nothing but a flat shade of gray.
What works best for me is the have a very high anistropy, either vertically or horizontally, and a very sharp reflection value to get those nice streaky highlights you seen in the real world. I also sometimes use a small wave bump amount to give a little variation to the reflections.
Tim Nelson
timnelson3d.com
Tim Nelson is offline
Old April 6th, 2005   #3 (permalink)
luckytohaveher's Avatar
Name: Ted Winkelpleck
I had the same problem a couple of years ago.
Create a light grey metal material, start with a max standard if you like.
Use a noise map for diffuse, specular, ambient, and bump with a setting of about 30 or so for the bump value. For the noise map place the 'levels' setting at about 2-3. Then make the mapping 1 tile in the x direction and 4 to 6 in the y direction.
That should do it. It is the 6 to 1 aspect ratio that will make it look good. If you really want to get tricky use the same map for the reflection map with a value of 20-40 (if you have the time)...
Good day.
luckytohaveher is offline
Old April 7th, 2005   #4 (permalink)
Singapore
thanks guys for your tips
see how it goes
mesht is offline
How to do matte stainless steel? johnnyc 3ds Max 2 March 12th, 2004 08:04 AM
Wooden Wall and Brushed Stainless Steel aflack 3ds Max 9 February 12th, 2004 05:42 AM
VrayMap Stainless steel Gander0 VRay Render 13 October 27th, 2003 03:15 AM
Stainless steel .mat Enginz-001 General Discussions 4 September 10th, 2003 01:10 AM
hairline stainless steel and frosted glass wongsengkeong Lightscape 4 September 5th, 2002 04:32 PM
