Hey, fellas!
We're having a problem here with Backburner. The thing is we installed the Backburner Server as a Windows service, ie, it starts automatically when you start Windows. We did that so we can use all machines as clients, like in a render farm. The problem is that once the students arrive and log in, Backburner continues rendering the job assingned, which is kind of bad (considering we have to teach using the same machines). Is there a way to make it stop the job when someone logs in? In addition, some machines are not connecting, showing the following error: 0000274C. What the heck is that? |
Name: travis schmiesing |
i don't run backburner as a servervice, but i also control our renderfarm through batch files. they are great for that. the way i have it set up, when you log nto the machine, there is a batch file in the startup directory. that batch file has a command that runs a batch file on the server. i also have the windows scheduler set to run the batch file every 6 minutes.
i set the farm up this way so that i could simply change the batch file on the server, and it would tell all of the machines in the farm what to do. whether it is to start something, stop something, shutdaown, switch to a lightwave rendering farm, ect.. i will post some more info on it tomorrow if you are interested. the info is a t work, and i am at home.
travis schmiesing |
attached is a zip file that contains a test file describing the setup of our farm that i wrote for our IT dept. last year. the zip file also contains batch files i use in the setup. the links below describe various batch file commands that you can use.
http://www.computerhope.com/overview.htm http://www.microsoft.com/resources/d...us/ntcmds.mspx
travis schmiesing |
| I thought I tamed Backburner | jucaro | 3ds Max | 4 | March 31st, 2005 09:28 AM |
| Backburner Server as service (serversvc) | jucaro | 3ds Max | 8 | December 21st, 2004 11:34 PM |
| Backburner Queue | Sawyer | Hardware and Technical Discusions | 2 | December 16th, 2004 10:48 AM |
| Servers and Backburner | jucaro | 3ds Max | 3 | October 14th, 2004 01:42 PM |
| Time LOG | mauarduz | General Discussions | 0 | July 15th, 2004 06:08 PM |
