Old April 7th, 2005   #1 (permalink)
Tim Nelson's Avatar
Default Anybody using Spyder ?
Just wondering if anybody is or has used this and what their opinions of it are.
http://www.colorvision.com/profis/pr...iew.jsp?id=101
I'm thinking about buying it since every time I have to print, I always end up getting mad because it never prints the way I want it.
Tim Nelson
timnelson3d.com
Tim Nelson is offline
Old April 7th, 2005   #2 (permalink)
DennisHolland's Avatar
Name: Dennis de Priester
Netherlands  Send a message via Skype™ to DennisHolland
Default Re: Anybody using Spyder ?
Hi Tim,
you can calibrate your monitor with Adobe gamma (Most pc's have it allready installed but also comes with Photoshop)...
Start Adobe Gamma, located in the Control Panels folder or in the Program Files/Common Files /Adobe/Calibration folder on your hard drive.
Do one of the following:
To use a version of the utility that will guide you through each step, select Step by Step, and click OK. This version is recommended if you're inexperienced. If you choose this option, follow the instructions described in the utility. Start from the default profile for your monitor if available, and enter a unique description name for the profile. When you are finished with Adobe Gamma, save the profile using the same description name. (If you do not have a default profile, contact your monitor manufacturer for appropriate phosphor specifications.)
To use a compact version of the utility with all the controls in one place, select Control Panel, and click OK. This version is recommended if you have experience creating color profiles.
This is from the Photoshop 7.0 helpfile. Must have Photoshop intalled though
Good luck,
Dennis
__________________________________________
PRIESTERMEDIA
3D Visualisaties & Presentaties
Rotterdam, the Netherlands
DennisHolland is offline
Old April 8th, 2005   #3 (permalink)
jackb602's Avatar
Name: Jack Bransfield
I've been using it for a couple of years to calibrate my Formac Gallery 1710 LCD. When I print to my Epson 2200, the print is nearly indistinguishable from the image on the screen. I recommend it.
Jack
Built Light
jackb602 is offline
Old April 8th, 2005   #4 (permalink)
President/Founder
Jeff Mottle's Avatar
Ahhhhhhhhhh! No! That Adobe Gamma is the worst thing you can use. Stay far far away.
As far as the new Spyder 2, we just bought the latest version at work and it is by far the best one they have made yet. It is very very good. Run, don't walk and pick your's up now! We just bought the Pro Studio version.
There have been a few threads about this recently so here is the link to the manuals I made a few years ago: http://www.cgarchitect.com/vb/showth...ht=ICC+profile
Jeff Mottle
CGarchitect.com
Jeff Mottle is offline
Old April 8th, 2005   #5 (permalink)
President/Founder
I should also premise that you can get about 80-90% of the way to getting matched prints if you have a proper printer ICC and a calibrated monitor. If you want 99-100%, then you need a controlled room and a small viewing booth.
Jeff Mottle
CGarchitect.com
Old April 8th, 2005   #6 (permalink)
Craig Ramsay's Avatar
Thumbs up Re: Anybody using Spyder ?
I use one too, they are very good if you use them properly.
Craig Ramsay is offline
Old April 8th, 2005   #7 (permalink)
Tim Nelson's Avatar
Thanks for the tip Dennis. I ran Adobe Gamma last night just to make sure I hadn't inadvertently missed it before, but then I remembered going through it already.
I think my monitor must be getting old because it has good contrast but even at its brightest settings is still a little dark. I have to use the Nvida gamma correction to give it a little boost.
Jeff, what would you say the advantage is of the PRO version over the regular Spyder package? Now that you guys have got me convinced, I'm excited to try it out, but I want to know if the standard package would be good enough for my needs.
Thanks.
Tim Nelson
timnelson3d.com
Old April 8th, 2005   #8 (permalink)
President/Founder
Tim,
We have only just started testing all of the other features that are specific to the Pro version, so I can't tell yet, but the base software itself (Pro and Non-Pro) it MUCH more user friendly than the original and will also calibrate monitors that do not have seperate gun controls. A really nice feature too is that it will match dual monitors too.
Jeff Mottle
CGarchitect.com
Old April 8th, 2005   #9 (permalink)
President/Founder
Here is a comparison matrix:http://www.colorvision.com/store_compare.shtml
Jeff Mottle
CGarchitect.com
Old April 8th, 2005   #10 (permalink)
angelo's Avatar
We used the Spyder a lot at my old place of work--nice because it worked on both CRT's and LCD's. Once we had our monitors dialed in, it wasn't hard to get output that was very close.
By the way, has anyone tried the printfx optical thingy that they also sell in one of the packages?
Angelo
angelo is offline
