3ds Max Autodesk 3ds Max
Old April 8th, 2005   #1 (permalink)
Question Mapping a curved road
Hello,
I am having a hard time mapping a road texture to a curved road object. I lofted a road section on an arc shape and would like to map the road texture to it lining up the road stripe in the texture to the middle of the lofted object. How is this done? Mapping a linear texture to a curved surface has me stumped, please help. Thanks.
Rusty
rcase is offline
Old April 8th, 2005   #2 (permalink)
Chad Warner's Avatar
Default Re: Mapping a curved road
When you create the lofted object, there is an option for "uvw mapping" , where you can tell it how many times to tile along the length and width. So you want to set up your material like you normally would, apply it to the loft, and then you will probably have to rotate the map in the material editor to make it line up with direction you want it go. It takes a lot of messing around, but you can get it to work. Check out Ted Boardman's tutorials on this site, he goes over lofting quite a bit.
-Chad
Chad Warner is offline
Old April 8th, 2005   #3 (permalink)
Thanks. I got it to work by adding Unwrap UVW modifier. That's the only way I could get it to work. Theres a sample pic below.
rcase is offline
Old April 9th, 2005   #4 (permalink)
bokkins's Avatar
Name: neil cristobal
Philippines  Send a message via Yahoo to bokkins
just a suggestion. staight line instead of broken lines for the curve, b'coz it means "no changing lanes on a curve".
bokkins is offline
Old April 10th, 2005   #5 (permalink)
vertexART's Avatar
Yugoslavia  Send a message via MSN to vertexART Send a message via Skype™ to vertexART
http://www.cgarchitect.com/resources...tutorial11.asp
www.3dcage.com
_____________________________________________
3DSMax8/MR/Vray
vertexART is offline
Road texture tutorial ecastillor Photoshop 8 November 7th, 2005 11:09 AM
Discussion about V-ray G-Buffer/Color mapping aea_arch General Discussions 8 February 4th, 2005 08:26 AM
mapping gizmo transformation !!?? virses 3ds Max 1 September 21st, 2004 05:07 AM
Terrain Mapping stinkyz 3ds Max 4 May 26th, 2004 12:08 PM
noise mapping on mirrored objects proces2 Autodesk VIZ 4 April 14th, 2003 05:17 AM
