| Finished Work Post your final 3D Art works here to be critiqued by other board members. |
Name: Yadi Krisnadi |
Hi, just finished exterior building project using maxwell alpha version. I made 3 options of scene.
I am newbie in Maxwell, usually I use lightscape. Comments & critics will helpful for me. Thank you. http://img142.exs.cx/img142/8696/grahabcblue907fc.jpg http://img142.exs.cx/img142/5381/grahabcorange8qf.jpg http://img142.exs.cx/img142/286/grahabcmorning6uj.jpg Last edited by Yadi Krisnadi; April 9th, 2005 at 10:24 AM. |
Another image rendering with Lightscape.
Thank You. http://img135.exs.cx/img135/3420/cam...chitect8me.jpg Last edited by Yadi Krisnadi; April 9th, 2005 at 10:52 AM. |
Hi, Yadi!
I'm afraid both images look far from what you might achieve with both Maxwell and Lightscape. Of course, I'm assuming you use tem because you want photorealistic results. There's a quite long way to go (IMHO) untill you get what your softwares can give you. |
Name: Devin Johnston |
Yadi... I think you need to work on your materials and also allow Maxwell to reach a higher sample level because there is still a lot of noise present. Give your materials some varying noise patterns and your windows need a little more transparency. You've also got something funny happening with your trees and cars, not sure what that is.
Thanks for your advice...i ll try play around with material.
For glass I used plastic material, I dont know how to make transparant on plastic material? Have you any idea? Thank you. |
Maxwell has it's own glass material it's called "Maxwell Dielectric" that is what you should be using. If you go to the Maxwell forem and do a search you will find plenty of info on how to use this material.
| Surreal Structures :: Maxwell interior test | Fran | Work in Progress (WIP) | 19 | December 21st, 2005 01:41 PM |
| Surreal Structures : Maxwell Piano test render | Fran | Maxwell Render | 18 | November 10th, 2005 05:41 PM |
| What Happened With Maxwell | Elliot | Maxwell Render | 9 | March 8th, 2005 12:30 PM |
| Maxwell Render for 3dsmax7 | ceballos | Maxwell Render | 189 | January 27th, 2005 02:22 AM |
