Old January 30th, 2006   #2 (permalink)
Tella
Tella's Avatar
Default Re: Upgrade from 32bit to 64bit
You should check if there are drivers for your hardware for 64bits. Usually programs are not the problem but the drivers. Nvidia has drivers for 64 bits. I had problems with the printer drivers; HP is not making drivers for 64 bits so I'm using my printer with the drivers of other printer which eventually worked. I had to search for the drivers of my wireless router antenna (succeded). AutoCAD 2006 installs the Net framework thing which didn't worked but you can download an update. Photoshop works fine.
Besides this problems I'm very happy with the change.
www.ftella.com
Tella is offline   Reply With Quote
