Old January 30th, 2006   #2 (permalink)
John Martin
John Martin's Avatar
Default Re: Problem to create multi-stories building
Buttman,
Try setting up your view in ADT to use low detail setting instead of medium detail or higher. It will not show hatching in ADT but will link to VIZ render much better. Also, try purging the autocad file to rid it of any unnecessary information. By the way, are you creating your view using different constructs and not having everything in one file like I have seen some folks try? It can make a BIG difference. You should be having no problems with you setup as it is virtually the same as mine. If you want to send me all your construct drawings I will see what I can do with it for you. E-mail me at john_deanna@comporium.net
John
John Martin is offline   Reply With Quote
