Name: Cheryl Pease |
I am basically wondering what the easiest & most accurate way of creating a tile pattern in photoshop is?
I know how to make a box a certain size but how do I copy it over a certain distance for the grout? Or is there an easier way of doing this?! Any advice would be very much appreciated! Thanks. |
Name: Chad Warner |
Easiest thing to do is to make your tile, either 1 tile or 2 tiles or 4 tiles, (depending on how much repeating you want) with grout lines. Select the tiles and the grout, and hit Ctrl+C (copy). Go to the Edit menu, and then "Define Pattern" The selection that you just copied will show up as a thumbnail, and you give it a name. Once this is done, you deselect the tiles, go to the Edit menu again, and choose "fill"... and then choose "pattern" and choose the pattern you just made, and it will fill the image with the tiles you made.
Name: Brian Zidovec |
Cheryl
I'll save you the hassle. Go to Acme Brick and download their manonry designer.. Way faster and and better than doing it in photoshop - and its free. http://www.brick.com/home-abc.htm |
Name: Pedro Penduko |
if you like to create your own original patterns you might want to learn from these tutorials:
http://www.tutorialoutpost.com/textures-patterns/120
| Tutorials creating furniture and manipulating drapes form | doraima | 3ds Max | 6 | September 4th, 2005 10:00 AM |
| Spanish Roof Tile Tutorial | raterry | 2D/3D Tutorials | 6 | May 9th, 2005 05:58 PM |
| Creating a complex Futuristic City | John Giummarra | General Discussions | 13 | March 2nd, 2005 03:09 PM |
| Conical Tile roof | Chad Warner | Autodesk VIZ | 2 | May 13th, 2004 08:34 AM |
| I need a roof (tile) libray...... | Ph03Nix | General Discussions | 3 | September 6th, 2002 08:09 AM |
