Name: roland nuqui |
hi guys,
i need a technical support regarding dual monitors. 1. i what to use 2 monitors in one unit? 2. i have nvidia geforce fx5200 hope you can help me on tis one. thank you in advance |
Name: Chad Warner |
If the card has two outputs, it's as simple as plugging a second monitor, and then right clicking on your desktop, go to properties, then settings. You should see a picture of two monitors with the second one greyed out. Click on the greyed out monitor and choose the option that says "extend my desktop onto this monitor"
#4 (permalink) | |
just disable the built-in then use the fx5200. sa add hardware mo makikita. for "dual monitor", there's a nvidia setting interface after you have installed the hardware that specifies what video output you'll use. its on display properties. right click on your desktop just like changing your wallpaper, its on the advance setting.
| Dual Monitor Advantages/setups | mhinks | Hardware and Technical Discusions | 6 | April 30th, 2004 09:30 AM |
| Dual Monitor. MS windows open in the middle | C.Vestal | Hardware and Technical Discusions | 7 | December 12th, 2003 01:35 PM |
| Dual Monitor Graphics Cards | will | Hardware and Technical Discusions | 10 | May 19th, 2003 03:53 AM |
| Dual Monitor and performance issues | HeDaCoM | Hardware and Technical Discusions | 3 | November 11th, 2002 12:23 PM |
| Dual Monitor Support without Nview!! | Jeff Mottle | Hardware and Technical Discusions | 0 | August 17th, 2002 06:39 AM |
