Old April 13th, 2005   #1 (permalink)
1eo
Default convert Autocad Drawings into "Good" quality jpgs... how??
Hello,
I want to import AutoCAD drawings into Photoshop so I can compose my drawings with 3D renderings of the building...
What techniques/ or file format do you guys use??
I have AutoCAD 2002 and my options seen limited, but I'm not that knowledgeable at AutoCAD... so I was hopping I could get some help from the pros.
Regards,
Leonardo
1eo is offline
Old April 13th, 2005   #2 (permalink)
1eo
Default Re: convert Autocad Drawings into "Good" quality jpgs... how??
Nevermind, I think I found what I was looking for
http://www.cgarchitect.com/vb/4045-autocad-photoshop.html
leo
1eo is offline
Old April 13th, 2005   #3 (permalink)
Banned
Name: tay ali othman al-rawi
Iraq  Send a message via Yahoo to tayali911
hi freind.
you have many techniques to convert to a good quality images
1-if you are working on shaded, wireframe or hidden viewports you can easily plot your viewport using "publish to web JPG" from plotter settings in plot menu,it is a virtual printer that you can plot sheets in to JPG files with a reslution you specify.
(plot-plotter settings-plotter name-"publish to web JPG")
2-if you want to convert a rendered view
you can easily change the rendering destination from render menu,clicking on the word "viewport" and change it to "file",then click "more options"botton to select the image type BMP PCX TIF TGA ....etc.
any thing you need just send a message to {tayali911@yahoo.com} and i'm ready to help you.
thank you,you are upon my head...
Tay Ali Othman -student-
Baghdad-Iraq-
tayali911 is offline
Old April 18th, 2005   #4 (permalink)
Dguarcello's Avatar
Name: Don Guarcello
Use Adobe Illustrator. Vector based graphics program that will save as raster.....
Dguarcello is offline
Old February 12th, 2006   #5 (permalink)
Pakistan
Default Re: Better JPEGs of AutoCAD Dwgs
Corel Draw also imports the DWG format ..and has very effective verctor editing tools. Try to get some better results..
tarakhaan is offline
Old February 28th, 2006   #6 (permalink)
RAYMOND's Avatar
do this in paperspace and create high res with the page setup..
RAYMOND is online now
Old February 28th, 2006   #7 (permalink)
quizzy's Avatar
you can download CutePDF printer from download.com
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old March 1st, 2006   #8 (permalink)
antonio_frias's Avatar
Name: Anthony Miguel De Frias
France  Send a message via MSN to antonio_frias
When I need to bring my autocad drawings into Photoshop, I begin by ceating a Postscript Printer (usually level 1, but that depends) in Autocad and then I print my autocad file into an EPS file. I then open the EPS file directly in Photoshop. I get very good results with this method. Where you have to be very careful is when you choose your line weights and printing scale in autocad. If your line weights are too big and you open the the EPS file in Photoshop with a small resolution, then the result is not great.
antonio_frias is offline
Old March 1st, 2006   #9 (permalink)
IC
IC's Avatar
Scotland
How great is CutePDF?
One of the best free utilities I have.
http://iainc.carbonmade.com/
IC is offline
Old March 1st, 2006   #10 (permalink)
ronel's Avatar
Name: arch ronel pabico
Philippines  Send a message via Yahoo to ronel
hello buddy....
just a simple step. export your drawings into .wmf extension. it can be open by any graphics software. then after you handedited it in photoshop save it in jpeg extension. dont export your drawing into jpeg extension. its resolution is not good and lines will become pixelate,but if its in wmf extension, lines are firmed even a very tiny lines.
good luck folks.
rkp_renderworks@yahoo.com
rpadc2002@yahoo.com
ronel is offline
Help! Exporting workable hidden-line drawings to AutoCAD from a 3Ds model? brinkadelic 3ds Max 3 December 5th, 2004 04:41 PM
AUTOCAD dwg file convert to PDF file Chris Potts AutoCAD/AutoCAD Architecture 9 October 8th, 2004 01:42 AM
AutoCAD 2002 -> Illustrator (How can I keep drawings to scale) ? mzagorski AutoCAD/AutoCAD Architecture 11 September 23rd, 2004 09:43 PM
inserting AutoCAD drawings in online portfolio vru AutoCAD/AutoCAD Architecture 1 September 23rd, 2004 02:32 PM
