Autodesk VIZ Autodesk VIZ
Old April 13th, 2005   #1 (permalink)
quizzy's Avatar
Default VIZ2005 network render error
This is what I get:
ERR Task error: An unexpected exception has occurred in the network renderer and it is terminating.
How can I find out what is causing this??
WIN XP pro
sp2
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old April 13th, 2005   #2 (permalink)
United_States  Send a message via MSN to BSArch98 Send a message via Yahoo to BSArch98
Default Re: VIZ2005 network render error
Michiel,
We've had those errors also (MAX 6)...and we've never been able to find out specifically what is wrong. We just try to clean up the file as much as possible, and perhaps split the scanlines during the rendering process to get it to render. It's a pain in the neck, and often takes a long time to render that way, but it's better to render something than to get errors all the time. I've never been able to track down anything that causes that error, no matter how much I've looked. Just trim as much stuff as you possibly can out of the file, and do anything you can to reduce the memory needed to render the file, and you should get better results....other than that, I don't know if there's anything else I can suggest.
Chris
Those who dream by day are cognizant of much more than those who dream only by night. - Poe
BSArch98 is offline
Old April 13th, 2005   #3 (permalink)
abicalho's Avatar
Can you render the file in that system manually? I would expect it to crash, as it's crashing when you netrender.
Alex Bicalho
abicalho is offline
Old April 14th, 2005   #4 (permalink)
quizzy's Avatar
Yes i can.. but only if I close all running programs like e-mail etc... So its propably a memory issue...??
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old April 14th, 2005   #5 (permalink)
abicalho's Avatar
Yep - add more swap file space to your system and that should work.
Alex Bicalho
abicalho is offline
Old April 15th, 2005   #6 (permalink)
quizzy's Avatar
My current swap settings are: 2048 - 4096 MB
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old April 15th, 2005   #7 (permalink)
Since this is a problem that I see regularly asked here on these forums I thought I would write a detailed solution to help people get their renders working properly.
The problem is that windows isnt allocating enough memory to viz.
Refer: Out of memory errors in VIZ
As mentioned in the previous document, they talk about a 3gb switch as one of the solutions.
Microsoft: By default, Windows can address a total of 4 gigabytes (GB) of virtual address space. By default, 2 GB of this is reserved for the kernel (operating system), and 2 GB is reserved for User mode programs.
When you put a /3GB switch into the Boot.ini file of the operating system, you reallocate the virtual address space distribution to give User mode programs 3 GB of space and limit the kernel to 1 GB.
The 3gb switch can be enabled in the boot.ini file.
An example of a boot.ini would be
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Pro with /3GB" /fastdetect /3GB
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /fastdetect
This is how we have ours setup. This will allow you on boot to choose if you want to boot windows with the 3gb switch enabled or not. It is also suggested you have 2 boot options (as above), one with and one without the switch, incase the switch doesnt work then you can boot windows normally.
There is a problem we have encountered however. When working in viz (not rendering) while the 3gb switch is enabled, a "Delayed Write Failed" error has occured. This can be fixed with a patch from Microsoft
Refer: "Delayed Write Failed" errors when you use the /3GB switch in Windows XP Professional
XP Service Pack 1 Users Note: Although the patch is not necessary for the previous error, you do however have to apply the patch to alow the 3gb switch to work under sp1.
Refer: Windows XP SP1 May Not Start with the /3GB or /USERVA Switch
This has fixed all our problems with netrendering and it has been tried and sucessfully tested on over 80 machines and have had them all rendering fine on a netrender.
It is strongly suggested you read all the information layed out above if you are new to doing this.
Good Luck
Luke
LukeC is offline
Old April 15th, 2005   #8 (permalink)
Just to note, we havent tried this method under SP2, and although Im told it works, i suggest you do some research first.
LukeC is offline
Old April 16th, 2005   #9 (permalink)
abicalho's Avatar
It works fine under XP SP2 - that's how both my systems are setup, and I'm up to date with all current hotfixes.
Alex Bicalho
abicalho is offline
Old May 5th, 2005   #10 (permalink)
Brolloks's Avatar
Name: Isaac van den Berg
South Africa
Hi
Try disabling the firewall under SP2 on xp. I've had mixed success with it switched on, but no hassles yet when it's switched off
Brolloks is offline
Network render avi file DrunkenMonkey 3ds Max 7 March 4th, 2005 11:05 AM
Net Render Error 0000274c lost in 3d world Autodesk VIZ 3 February 8th, 2005 06:20 AM
error msg in network rendering blaz 3ds Max 4 July 20th, 2004 07:21 AM
Network rendering error message Dan J Hardware and Technical Discusions 4 February 19th, 2004 03:41 AM
Region Selected Rendering through Network Render nisus 3ds Max 8 November 25th, 2002 06:52 PM
