Old April 14th, 2005   #1 (permalink)
Malaysia
Default What is the best setting for animation using VRAY?
I am animating a 4 minute animation of a city scape...there are a lot of objects in the scene with reflections. What i want to ask is..does anyone know the best setting for this kind of animation for VRAY? what are subdivs and does it help with the jittering problem caused when doing an animation with VRAY?
I need to submit this work in a week time..so any reply or help would assist me greatly. Thanks
cxdesigner is offline
Old April 21st, 2005   #2 (permalink)
Woody79's Avatar
Default Re: What is the best setting for animation using VRAY?
if you can afford the frame times then stick it on high animation, and caculate a map every 25 frames or less if your camera is moving alot.
increasing rays and subdivisions will help, but dont go crazy, i usually have this set at 32/32, but if its a stuborn sob, then crank it up to as high as 80/60 maybe. make sure your reflection depth is set to its lowest limit, try not to have too many glossy reflections. if its pal or ntsc res then you can get away with alot. ie taking reflections of alot of things.
Architectural Visualiser
:::::Portfolio-Radiosity Tutorials:::::
www.vanilla-box.co.uk
Woody79 is offline
Old July 13th, 2005   #3 (permalink)
Name: shanmuga sundar raj r
hi,
there are some good tips about vray settings for both interior and exterior renderings in http://www.vray.info and the ultimate vray resource in http://www.chaosgroup.com/
from there you could find a lot of research links leading to various case study done by Vladimir Koylazov and many other experts.
thanks
shan
shan is offline
Ten vray questions steve VRay Render 10 September 13th, 2008 10:20 PM
Vray, Maxwell...................?? bully712 VRay Render 16 April 5th, 2005 08:36 AM
Vray and Brizal Rio plug in Chris Potts Other 3rd Party Renderers 7 September 16th, 2004 02:01 AM
about Vray versions and VIZ 4.2 salf VRay Render 8 March 2nd, 2004 03:47 AM
VRay against Vray and ... Sergio VRay Render 15 May 30th, 2003 09:09 AM
