Old April 18th, 2005   #1 (permalink)
Dibbers's Avatar
England  Send a message via MSN to Dibbers Send a message via Skype™ to Dibbers
Unhappy HD probs
In the last 2 days, my system has become very unstable (weird errors and crashes etc), very slow to boot up and launch programs, and the hard drive has been making some very unusual crackling and clicking noises, even when Idle. I thought it might be virus (even though it's not connected to the internet), but I've scanned my system and all is OK. I've run Chech Disk, and all is clean (although it took 3.5hours to do it).I checked 'speed fan' (a program that monitors the fans and HDs) yesterday and all was good, but this morning it reports the health of my Maxtor 120gb Hard Drive at about 40% !
Am I right in thinking my HD is about to die, and if so can I have the contents 'ghosted' onto a new HD ?
Hard boiled eggs and nuts....Mm!
www.idenby.co.uk
Dibbers is offline
Old April 18th, 2005   #2 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
Default Re: HD probs
i would back everything up asap. it sounds like you hard drive will stop working very soon. i have had this happen, and lost work and libraries. it is no fun.
travis schmiesing
Old April 18th, 2005   #3 (permalink)
Dibbers's Avatar
Just taken it in, and they think it's going to die too. I just hope they can boot it up 1 more time to be able to copy everything across. It's my C Drive where all my programs are (my data files are on another drive), so I can re install them if neccessarry, but a bit of a pain.
www.idenby.co.uk
Dibbers is offline
Old April 18th, 2005   #4 (permalink)
when i had this happen before we think the problem was related to a speaker to close to the hard drive. i lost 2 drives within a week. the speaker was supposedly shielded.
travis schmiesing
Old April 18th, 2005   #5 (permalink)
Dibbers's Avatar
My speaker is about 600mm from the HD, so it won't have been that.
www.idenby.co.uk
Dibbers is offline
Old April 18th, 2005   #6 (permalink)
3dp
Name: david pinnington
Bahrain
happened to me 18 months back
pulled drive and put in sealed bag into fridge overnight (not freezer) and it was enough to save the data and the job at the time
hope you save it all
can i have everything louder than everything else please
3dp is offline
Old April 18th, 2005   #7 (permalink)
President/Founder
Jeff Mottle's Avatar
Must be going around, One of my drives is doing the same thing. I've had it with failign drives, happens about every 2-3 years with me, so I just ordered an 8 channel RAID controller and am picking up 4 new drives to run in a RAID 0 configuration. Unless the whole array goes or is killed by a virus then I'll be safer. I hope. I just hope everything is ok before the new drives get here. My drive mirrors have been less than successful the last week and as of this moment I'm not able to access my computer remotely, so I'm a bit worried it's gone.
Jeff Mottle
CGarchitect.com
Jeff Mottle is offline
Old April 18th, 2005   #8 (permalink)
bully712's Avatar
My computer is making a noise when starting up. Once it boots up, it's fine. I thought maybe one of my fans was going bad. Could my problem also be the HD? I just installed a secondary HD a few months ago. Could it be my primary HD?
wireboxdesign.com
rendering the imaginative
bully712 is offline
Old April 18th, 2005   #9 (permalink)
You'll probably want to consider at least a RAID 1 (mirroring) setup, if not RAID 5. RAID 0 (striping) will give you great performance but no redundancy or fault tolerance. Good link to RAID definitions:
http://searchstorage.techtarget.com/...214332,00.html
Nicholas Moshenko
DesignStor
www.designstor.com
moshenko is online now
Old April 18th, 2005   #10 (permalink)
Dibbers's Avatar
I do already have a RAID (striped) set-up
www.idenby.co.uk
Dibbers is offline
Rpc Shadow Probs! doujay888 Work in Progress (WIP) 7 December 11th, 2004 08:08 AM
