| Lightscape Autodesk Lightscape |
Name: paul malinao |
has this happened to you before?
a perferctly good block in LP then when you initialize a good number of meshes dissappear... i tried re modellin the block, change layer, explode it name it... and it still dissapears |
You have too small meshes.
Try lowering lenght tolerances (Process Paramtears) before you hit Initiate. Happend to me before a lot, because I overmodeled my objects. But you said it happend with LS blocks. Thats strange ...only if they are YOUR custom Ls blocks.
Beeeee! |
I have seen that, with lights (a form of blocks). Just disappeared from the .ls file. You can lower the lengths, but you can create a situation where the file become unworkably large by doing so.
After some considerable stress on a big project a few years ago (and this only happens a day or two before your deadline) I finally took note of what was getting 'lost' and initialized those layers seperately, and the main file with them off, then merged the two .ls files. It worked. |
del82... yep they are my blocks
ernest... tried separating it in different files too didnt work for me... and yes they are very small meshes but i cant help it because the block is a reincarnation of old english monarch furniture. so theres a really a lot of flowers mouldings carved into it. thanks guys i'll try lowering the process parameters Last edited by CEREAL_KILLER; April 20th, 2005 at 11:55 PM. |
#5 (permalink) | |
i tried it didint work... what i did was exploded the block then re-model the dissappearing meshes in LP with "create mesh" a bit gung-ho approach but it worked took time though.
| mystery shadow? | TjQs | Work in Progress (WIP) | 6 | March 23rd, 2004 04:06 AM |
| Request: How to do neat meshes when modelling | Ras | 3ds Max | 9 | November 6th, 2003 02:03 AM |
| meshes that disapear PLEASE HELP ME - URGENT! | brunojac | Lightscape | 2 | October 24th, 2003 09:09 AM |
| 3d furniture meshes - models | fi3er | General Discussions | 3 | September 25th, 2003 01:02 AM |
| murder mystery | kunstraum.tv | Finished Work | 4 | February 22nd, 2003 05:01 AM |
