Old February 7th, 2006   #2 (permalink)
karl zacharias
Name: Karl Zacharias
Default Re: Boolean Problems
a tip for booleans I learned here is to attach all the boolean objects into one editable poly...and boolean all at the same time...with your arched window I would make the boolean object from a line and extrude the profile, turning it into a poly and attaching the box boolean as an element...making one object...booleans are someties unpredictable...try using poly walls on a subobject level to create openings.
karl zacharias is offline   Reply With Quote
