Name: Vincenzo Crupi |
Hi everyone,
I have to repoduce a rendering for a billboard ad (about 96"x168" @ 50/75 dpi) and was wondering if anyone knew of any software that will allow me to blow-up a rendering/image without losing too much resolution. I'm having problems rendering it so big in 3ds max, keep getting "out of memory" errors, so i've decided to render it at a lower res and see if i could blow it up without losing too much resoultion. I can swear that i read something about a software that does this very well on this site in the past. If anyone has any knowledge of this, can u please post ASAP. Also, if anyone can tell me if 50 dpi is enough for this ad, that would be great as well. Thanks |
look for bigrender or bgrender on This Page
http://www.scriptspot.com/Main_Scrip...nder&Sort=Name or direct i Think is http://www.scriptspot.com/download.asp?ID=2062 ** maybe render the sections @ 100 dpi or 150 ** i just used this .ms about 3 weeks ago to render a 36" x 24" plotfile @200 dpi i too was getting a "out of memory" error This will create 2x2 or whatever you select sections but beware There WILL BE A 1x PIXEL BLACK LINE ON THE LOWER AND RIGHT SIDE of EACH of the sections, so remember to "eliminate"" THIS otherwise TOTALLY COOL extremely helpful, bailed me out of a jamb Last edited by vizwhiz; April 21st, 2005 at 04:42 PM. |
Here, check this out. Supposedly you can render small sizes & this will do a good job at super-sizing them. http://www.lizardtech.com/products/gf/
I've used it once in demo, but didn't really take the time to compare it to regular photoshop re-sizing. |
Name: travis schmiesing |
maybe tweak shadow maps and such so less memory is used, ...or, have you tried cranking up the virtual memory, even though it will slow things down overall?
travis schmiesing |
I think you should also try this app. Originally known as Shortcut S-Spline
http://www.trulyphotomagic.com/short...rie_info&cat=3 Best Regards, Meher www.drapefx.com |
Name: david pinnington |
my vote goes with s-spline
usedthis several times to go from 72 to 300 dpi in one hit much better than the p-shop interpolations for resize imho for me it's mainly clients wanting a image on a site signboard so for this type of work it's no hassle to take a a3 image 2480x1753 and blow it up to 3 x 2 metres
can i have everything louder than everything else please |
Name: Luka DM |
Use Genuine Fractals from Lizardtech http://www.lizardtech.com/products/gf/
It is a plugin for photoshop and will handle any image over 1000x500 pixels in size. We use it all the time and it works a treat. |
#8 (permalink) | |
great....thanks for all the rapid responses! I think I'm going to give the s-spline a try. It sounds like something that could really help out for this and future projects.
| Please Read This Before Posting Images | Rick Eloy | Finished Work | 31 | March 15th, 2008 08:20 AM |
| Please Read This Before Posting Images | Rick Eloy | Work in Progress (WIP) | 3 | August 28th, 2007 04:31 PM |
| Good resource for sky images? | Telemachus | Autodesk VIZ | 4 | March 14th, 2005 09:24 AM |
| Linking to thumbnail images | Jeff Mottle | Comments and Feedback | 7 | March 16th, 2004 03:08 PM |
