I am configuring a new workstation since my dual xeon workstation bogged down (for the nth time). this time the xeons will handle the renderings using backburner while the new desktop will be for most office work and modeling, maybe little rendering.
specs: AMD64 3500+ 2 gb RAM Nvidia 6600 Raid 0 configuration DVD writer +/- Windows XP Pro 64bit I will now be using viz2006 primarily and mentalray and probably maxwell. Now, will max or viz and other plugins work if I use a a 64bit Xp Pro or should i use the 32bit version? Which harddrive performs better in terms of speed and reliability? Seagate SATA 2 or Maxtor SATA's? any advice will be appreciated since i will be purchasing the workstation. I thought of using a nvidia quadro PCIe but budget wont allow it. |
Name: Ihab Kalache |
that is the same configuration I have except for windows 64 bits.
I read somewhere that you won't find any noticeable improvement in performance between SATA2 and SATA before a couple of years when they change the way hard drives work. mechanical limitations... |
Name: Lambros Potamianos |
I got myself a new workstation:
AMD 64 4000+ (very very fast), 2 gb RAM (which is more that enough), stripping raid, but I installed XP Pro 32bit. I read that max works ok in 64bit, so I guess that viz will work too. About the plug ins, I am not sure whether they will work or not. But I think that XP 64 have not hit the market yet (I think that the beta version testing ended a month ago). On what concerns hds, I kind of dislike Maxtors (I have lost a couple of them in the past, along with my data!), I use Western Digitals mainly. Actually on the new machine, I use two 36 GB 10.000 rpm SATAs stripped (for system), along with a 200GB SATA for data. It really rocks. Finally, I got an ATI Fire GL 7100 for about 850€ (I think it is a bit cheaper in the US) and I am reeeeeeeaaaaally content! |
Name: Stanley Shi |
If you're using 3ds Max, I suggest using Intel CPU instead of AMD's, because 3ds Max and Vray has been optimized for intel CPU (from version 6) and it should be much faster than AMD when using these software. Also there seem to be some problem with AMD's new 64 athlon CPU, lots of tests show when render a image a AMD 64 3000+ is no better than AMD athlon 2500. But if you're using MAYA, AMD seems to be a better choice.
I have 3 AMDs and 2 Intels and I have no problem whatsoever with AMDs. In fact, a 3.4+ AMD64 in a laptop with 512MB renders as quick as a 3.4 Pentium(32 bit) in a desktop with 2GB ram. I haven't read any problems with XP 64 pro, but I suggest you keep an eye on hardware sites.
#9 (permalink) | |
Softquadro is the best way to go if you have limited funds. Quadro's may not be worth it, but that's jst my opinion |
#10 (permalink) | |
then i'll go for the 64bit Win xp pro. |
| is this workstation OK? | Sindala | Hardware and Technical Discusions | 0 | April 24th, 2005 06:12 AM |
| Entry Level 3d Viz Workstation | GI Dude | Hardware and Technical Discusions | 6 | January 17th, 2005 06:09 PM |
| Ideal Workstation Configuration | Elliot | Hardware and Technical Discusions | 34 | September 22nd, 2004 07:27 PM |
| Workstation Specs : Opinions? | mbr | Hardware and Technical Discusions | 20 | April 29th, 2004 07:33 PM |
| Dell Precision 650 workstation | JM Ataide | Hardware and Technical Discusions | 40 | April 25th, 2003 06:37 AM |
