Cinema 4D Cinema 4D
Old June 9th, 2005   #1 (permalink)
Wokka's Avatar
Name: Warwick Lloyd-Martin
Australia  Send a message via Skype™ to Wokka
Default Sun object
Hi All,
I'm currently making a series of sun study animations and would love to show in frame an indication of Lat-Long, date and time. I assume all this info can be obtained by using a sun tag on my sun object. Does anyone know of an expression that will create a little 3d Object I can sit in the corner of the frame, attached to the camera and give constant readouts of date and time?
Also, I get an error message trying to access the tag's properties.(see attached). Anyone got any ideas??
Thanks in advance
(BTW PC based)
Wokka
C4D R10.5 - VRayforC4D 1.087
ArchiCad R11
Wokka is offline
Old June 11th, 2005   #2 (permalink)
Germany
Default Re: Sun object
Hi,
you should update to 8.207 and run the language installer for this version if you don't use english. This seems to be a mix up of language support and program version.
Hope this helps
Björn
srek is offline
Old June 11th, 2005   #3 (permalink)
Wokka's Avatar
Srek,
Sorry, I'm running R9 in English? Any other ideas.
Cheers
Wokka
ArchiCad R11
Wokka is offline
Object Glow? Dan J Autodesk VIZ 12 August 14th, 2007 03:41 PM
copying object refferencing a line object Bugga_Guy 3ds Max 4 April 6th, 2005 12:02 PM
Noise to glass object? akzit Autodesk VIZ 2 March 23rd, 2005 10:12 AM
"Xref object" won't recognize new geometry after I xref object RTurner Autodesk VIZ 0 August 26th, 2004 12:19 PM
Lighting go trough object! taufux 3ds Max 6 April 5th, 2004 07:36 AM
