Name: Brian Kitts |
I've been using V-ray for about a year and I am getting to the point where I know the settings well enough to crank down what i need for optimal time vs. quality. But the one thing that has eluded me is the benefits of doing a single prepass versus multiple prepasses. I normally don't have that much of a breakdown with shadows, or splotchyness (new word for webster) that I can't control with adjusting subdivisions.
So the question is, what is the benefit of multiple passes.... is there something I'm overlooking or not seeing, I've been pretty happy with the renderings I've been getting on one pass. attached is my latest single pass rendrering - C&C also welcomed thx in advance for your opionions -bk Last edited by BrianKitts; June 13th, 2005 at 01:01 PM. |
Name: Stephen Leworthy |
i usually render in a single pass too. i find a layered pass is usefull for ammending shadows or gi or reflection properties for example.
i too would be interested to hear other people's experiences why they multi pass. it certainly isn't for speed. large render houses like ILM and Weta do it as standard. nice image btw. i'd just lessen the gi bounces slightly. |
Name: Ihab Kalache |
single pass here too. With animations I think multi pass helps more becasue rerendering the animation becasue you want darker or lighter shadows would make you miss the deadline. if you can do it for renderings why not? but I really haven't seen the necessity for that except on 1% of the projects.
Name: Victor Erthal |
I thought the muli-passes were used to get the best quality versus speed. Since it would only pass with a higher resolution where needded, instead of doing it on the whole image. But i guess i'm wrong. Dit it really render faster that way?
some plugin renderers re render the whole scene and extract from it reflections, then rerender the whole scene and extract from it specularity and then rerender the whole scene and extract from it shadows and then rerender the whole scene and extract from it beauty pass...etc.. kinda like my post : AWKWARD
I think Brazil is like that. haven't tried Vray...Max scanline does all in one render. update. just tried mental ray and it renders each pass by itself. for ten different pass types it renders ten times. but it is fast in those that contain little info. Last edited by ihabkal; June 13th, 2005 at 01:40 PM. |
Name: Sawyer Fischer |
Just to clarify - you are talking about prepasses ("currently calculating prepass 1 of 4) not effects (reflection, z buffer) passes right?
#7 (permalink) | |
at least i was talking exactly about that. the irritating prepasses. |
Name: Craig Ramsay |
Hmmm i'm a little confused as to what you guys are talking about. If you mean multi layered passes then personally I only really use them for photomontage work where I may need to blend in shadows or reflections to match the photograph. If my renders are completely CG then I hardly ever need to use multi layered passes.
| *Complex *roof tuto. (with multiple Gables/Hips&Dormers and at different plate H.? | archkre | AutoCAD/AutoCAD Architecture | 17 | November 20th, 2004 09:00 AM |
| multiple uvw maps | pickle | General Discussions | 6 | November 3rd, 2004 09:33 PM |
| Render Passes in V-Ray? | ShaunDon | VRay Render | 3 | August 18th, 2004 05:47 AM |
| Rendering Multiple Camera Views | steven martin | Autodesk VIZ | 6 | June 16th, 2003 01:16 PM |
| Editablepoly or multiple commands in edit stack, which one do you prefer? | smoky | General Discussions | 4 | May 22nd, 2003 08:44 PM |
