Old June 13th, 2005   #1 (permalink)
mskin's Avatar
Name: herbert mellville
Default hal.dll
Just replaced motherboard and processor (amd atlon 64 3500). Re-formatted and installed XP Pro. After install, upon boot, i get a "Hal.dll corrupt or not found" error. Anybody have experience with this? I've tried a numberof things, including installing sp2 wich replaces the existing hal.dll file. hal.dll is in system directory, but still - error occurs. windows will not start normally unless i have the cd in. if i put the cd in, i don't get the error and boot normally although i cant install many programs. help appreciated.
thanks
mskin is offline
Old June 13th, 2005   #2 (permalink)
mskin's Avatar
Default Re: hal.dll
tried bootcfg /rebuild from repair options.... did not work.
mskin is offline
Old June 14th, 2005   #3 (permalink)
Richard McCarthy's Avatar
Default Re: hal.dll
Try this :
http://www.kellys-korner-xp.com/xp_haldll_missing.htm
and this :
http://support.microsoft.com/default...b;en-us;330184
Don't mess with my hat !!
Richard McCarthy is offline
Old June 14th, 2005   #4 (permalink)
mskin's Avatar
Default Re: hal.dll
I have already tried all these. no go. could it possibly be some sort of hardware issue? this is a fresh install of win xp pro, reformatted hard drive. have reinstalled multiple times... could be cd has scratch? im going nuts.
mskin is offline
Old June 15th, 2005   #5 (permalink)
Default Re: hal.dll
Have a look here. Might help.
http://www.daniweb.com/techtalkforums/thread10062.html
Just ask. You never know!
JHalton is offline
Old June 15th, 2005   #6 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
Default Re: hal.dll
What's amazing about this is that we have something running our machines called 'HAL'
No-one was at work in the Un-Intended Ironies Department at Microsift that day?
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Old June 15th, 2005   #7 (permalink)
Default Re: hal.dll
''I dont want to talk about it Ernest. I think you are been irrational Ernest. What seems to be the problem ernest....Daisy Daisy give me your answer do........'' heh heh heh
JHalton is offline
Old June 15th, 2005   #8 (permalink)
Default Re: hal.dll
Hardware Abstraction Layer.
this i know from the following act of gracelessness: was using the end of the vacuum to suck the dust and crap out the inside of the comp and accidently knocked the r.a.i.d. connection from the hdd off its mb prongs (so gently that i didn't even notice). as i learned, during the p.o.s.t. the bios first checks the status of the hardware attached to the motherboard, then segues into the software, which kinda makes sense.
short story, make sure everything is well attached
MooseDog is offline
Old June 15th, 2005   #9 (permalink)
Default Re: hal.dll
Originally Posted by JHalton
''I think you are been irrational Ernest.''
I'm being perfectly rational. In fact, I'm going to go out into space without my helmet in a pod that is controled by a bi-polar artificial inteligence.
Ernest Burden III
AcmeDigital
Old June 16th, 2005   #10 (permalink)
mskin's Avatar
Default Re: hal.dll
thanks for the help, or should i say humor. im just glad to see a couple of people had some fun at my expense while beeds of sweat poured from my forhead onto my motherboard. I didn't spend the time to configure my bios. Had a PCI sound card installed with onboard sound card set to on, BIOS was looking to slave hard drive for motherboard, and SATA was on (while i have no SATA drives). after making these changes in the bios, xp installed fine.
mskin is offline
