Name: Greg Hess |
http://www.3dluvr.com/content/maxbench.php
*=SSE ON in Max5, or Max4.26 Its interesting to note that the Dell system (which is actually significantly slower then the boxxtech system) costs MORE then the boxxtech system. Working on the vray tests now, then going to lightwave. Quick Notes on the Boxx System.... Compact (About the size of a 4U box, but vertical). #@%$@#% Fast. Extremely Quiet. (Can't tell its on) Excellent CPU Temps. (32C Idle, 39-40C Heavy Load) Very Neat. (Best cable management I've ever seen) |
Name: Greg Hess |
www.3dluvr.com/crossbow/incoming/setup.jpg
The computer on the far left is the Dual 2.8B Xeon [Boxxtech]. The one on the far right is my Dual Athlon, the one on the desk is the Shuttle SS51B 2.66B Pentium IV. I'll have more pics of the boxx system when the review is done, I'm just posting preliminary tests so everyone can get fast feedback. |
Name: Christian Miranda |
Hi Greg,
Hey, I see one 191T. You´re lucky. I wonder how would you feel if you exchange that viewsonic for a second 191T...that would be heaven. Are you still developing the more multi-threaded friendly set of benchmarks? Hows it comming? Keep up the great work on the hardware front end. rgds, Christian |
Name: Greg Hess |
Hehe. I am currently trying to sell the vg191b to my parents so I can buy another 191T. Are you still developing the more multi-threaded friendly set of benchmarks? Hows it comming? Yes. There are 18 planned tests per application. For 3dsmax we have the original 9 (as already seen) with 3 more scenes rendered in vray. The vray scenes are pretty nasty (very large scenes with tons of detail) and include two interiors and one exterior shot. Early tests indicate that vray is extremely multiprocessor friendly, so should give some awesome results. (There are 4 applications...Maya, XSI, Lightwave, and Max, or 72 render tests per system...GAH!!!) |
WHAT? 18 tests per app? A total of 72 tests?
How much time will it take to bench. a single system? Aren´t you afraid of spending your whole life benchmarking workstations??? Just for fun... You set standards in hardware reviewing Greg. |
Name: Greg Hess |
Its not to bad, cause there are multiple machines. I can bench t wo machines at once, while using the 3rd to do work, or play computer games...mmm EMI, gotta have it.
Name: Marc Lorenz |
you know what would really rock?
3 x 191T right now i try to decide between 2 x 191T and 1 x 210T (21" 1600x1200). 3 19" screens would be ultimate, just imagine the appearance (client impressing machine), but i can't really justify the costs vs. benefit. |
Hi Marc,
My advice would be: IF YOU DO 3D GO FOR TWIN 191T´s! I´ve been researching LCD´s and found out that the 210T is not good for fast moving objects(such as viewport object manipulation) and/or movies. Its response time is only 35ms. The 191T has a response time of 25ms which is starting to look good. regards, Christian [ January 13, 2003, 07:28 PM: Message edited by: Christian Miranda ] |
