Cinema 4D Cinema 4D
Old June 17th, 2005   #1 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
Default wood floor material 'gift'
I had posted this on CGtalk when someone asked for ideas about wood floors, might as well put it here, as well.
This bit of floor (c4d file, some polys and 1 mat) was a combination of mapping and modeling--no textures--just shaders within Cinema.
The mapping will fall apart if moved even a little. But the texture tag, if applied to a single plane shoud behave nicely. It would need to be rotated 45 degrees using the texture tool for a regular floor.
It is a piece of the floor in this illustration:
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Old June 17th, 2005   #2 (permalink)
Default Re: wood floor material 'gift'
Wow Ernest, I've not seen this image before. It's spectacular! Mind sharing a bit of your process for creating the image? Particularly about your post-processing method?
Eric Adams
http://particlerealities.blogspot.com/
Eric is offline
Old June 17th, 2005   #3 (permalink)
It's more of the same. Have you read my earlier posts answering that basic question? Or read my project log from earlier this year? It's all covered in those.
But in a short version--
I take a regular GI raytrace and add noise, play with contrast and saturation. That's it.
Thanks for the kind words, too!
Ernest Burden III
AcmeDigital
Old June 17th, 2005   #4 (permalink)
STRAT's Avatar
Wales
EBIII has a wonderful style.
STRAT is offline
Old June 17th, 2005   #5 (permalink)
Thanks. I'm tired of it, but it sells renderings.
Stephen
Would you DL the file and give me an opinion on the shader? It's a frankenstein, but I was pleased with the results. I wonder what you think?
Ernest Burden III
AcmeDigital
Old June 17th, 2005   #6 (permalink)
STRAT's Avatar
Wales
sure, no probs. but it'll have to wait until i get to work on monday. i no have cinema at home
i'll report back....
STRAT is offline
Old June 17th, 2005   #7 (permalink)
CHE
CHE's Avatar
United_States  Send a message via MSN to CHE
Thumbs up Re: wood floor material 'gift'
Ernest,
This rendering is sweet. I really like what you do to your images in post-production. If I'm not mistaking, it looks like you apply a reflective material to some of your geometry just to get a reflection pass and then use it as a layer in Photoshop. I've learned tons just by looking at and analyzing your beautiful renderings. Thanks for sharing.
Ernesto
CHE is online now
Old June 17th, 2005   #8 (permalink)
I do. That's because I can. Cinema easily saves layered files, and I love being able to play around with reflections in post. Although, I rarely adjust them by very much, as I've already set the reflectivity to what I want as setup to render.
Ernest Burden III
AcmeDigital
Old June 17th, 2005   #9 (permalink)
Tim Nelson's Avatar
Nice one! Does c4d do area shadows? Those shadows from the sun stick out to me as being just a little too crisp compared to the rest of the rendering.
Tim Nelson
timnelson3d.com
Tim Nelson is online now
Old June 17th, 2005   #10 (permalink)
Yes! But not this week.
Area shadows are so slow, along with its beautiful 'stochastic' rendering mode. Too slow for production.
Ah, but now I have Maxwell, and....oh. It's slow, too. Nice shadows, though.
Besides, I have always used sharp shadows or sunlight, because that was just what you do. And I think in reality that shadow would still be fairly crisp.
Ernest Burden III
AcmeDigital
problems w/ wood & radiosity akzit Work in Progress (WIP) 8 September 23rd, 2004 04:42 PM
Challenge #8 - 100 wood textures lemog Monthly Challenge Work in Progress (WIP) 8 August 15th, 2004 08:52 PM
wood rendering illyrianeye Autodesk VIZ 3 June 14th, 2004 01:13 PM
Blurry wood..??? SEIF Lightscape 6 June 3rd, 2004 10:08 AM
cracking a piece of wood with 3ds max 5? schmoron13 3ds Max 1 January 7th, 2003 03:41 AM
