3ds Max Autodesk 3ds Max
Old June 18th, 2005   #1 (permalink)
Name: Pete Rodriquez
Netherlands
Default 3d to 2d using 3ds max and autocad
3ds max works well when you import 2d plans and sections from autocad to 3ds max. However, some design processes work the other way around. Can you design in 3ds max, cut section and export to autocad in an accurate and effective way like form z?
Pete is offline
Old June 18th, 2005   #2 (permalink)
STRAT's Avatar
Wales
Default Re: 3d to 2d using 3ds max and autocad
exported 3d max into acad on a daily bases successfully via 3DS or DWG, but must admit i've never exported 2d max back into acad. without having any software infront of me right now i'm sure it'll work via DXF or DWG
STRAT is offline
Old September 22nd, 2005   #3 (permalink)
Name: A.J. van Bochove
Netherlands
I'm begun with modelling in Acad (4 years ago), but now when I model everything in Max... (at home).
At work I'm forced to use Acad 2006 LT (because I'm 'the new one') and I'm looking for a way to use max modelling and put dimensions and hatches at the model in Acad.
This may also be 2D (flatten)
1,, model in max
2,, export to acad to put dimensions
3,, make plot
4,, change dimension in max
4,, export to acad again in same drawing.
5,, check dimensions (associative)
6,, make new plot
Are there bottlenecks/ problems to keep in mind.
Some advise would be appriciated.
Thanks.
ajvbochove is offline
3DS Max or Autocad Sergio 3ds Max 21 October 1st, 2007 09:18 PM
AutoCAD vs 3ds Max modeling ? muzzy 3ds Max 22 October 4th, 2006 05:43 PM
autocad to 3ds max DAN212222 General Discussions 2 September 14th, 2004 02:11 PM
importing and uvw map applying autocad model in 3ds MAX j.k 3ds Max 3 May 13th, 2004 11:20 PM
