Old March 30th, 2003   #11 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
CINEBENCH 2003 v1
Tester : ts
Processor : IBM IntelliStation
MHz : 2ghz xeon
Number of CPUs : 2
Operating System : win 2000 pro
Graphics Card : NVIDIA GeForce4 Ti 4600
Resolution : 1280x1024
Color Depth : 32 bit
Rendering (Single CPU): 197 CB-CPU - 2 min 13.9 sec
Rendering (Multiple CPU): 363 CB-CPU - 1 min 12.6 sec
Multiprocessor Speedup: 1.84
Shading (CINEMA 4D) : 184 CB-GFX
Shading (OpenGL Software Lighting) : 809 CB-GFX
Shading (OpenGL Hardware Lighting) : 986 CB-GFX
OpenGL Speedup: 5.36
travis schmiesing
crazy homeless guy is offline
Old March 30th, 2003   #12 (permalink)
quizzy's Avatar
CINEBENCH 2003 v1
Tester : Michiel Quist
Processor : P3 Dell
MHz : 1000
Number of CPUs : 1
Operating System : Win2K
Graphics Card : Matrog G450
Resolution : 2048x768
Color Depth : 32bit
Rendering (Single CPU): 108 CB-CPU 243 secs
Rendering (Multiple CPU): --- CB-CPU
Shading (CINEMA 4D) : 113 CB-GFX
Shading (OpenGL Software Lighting) : 320 CB-GFX
Shading (OpenGL Hardware Lighting) : 149 CB-GFX
OpenGL Speedup: 2.84
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old March 31st, 2003   #13 (permalink)
Greg Hess's Avatar
CINEBENCH 2003 v1
Tester : Greg Hess
Processor : Athlon 1800+ XP
MHz : 1530
Number of CPUs : 1
Operating System : Windows 2000
Motherboard : ECS K75SA
Ram: 512 Megs of Mushkin PC2700
Rendering (Single CPU): 192 CB-CPU (137 Seconds)
More streaming in. Hehe abuse of power.
[ March 31, 2003, 10:19 AM: Message edited by: Greg Hess ]
Greg Hess is offline
Old March 31st, 2003   #14 (permalink)
Greg Hess's Avatar
CINEBENCH 2003 v1
Tester : G Man
Processor : Dual G4 (DDR)
MHz : 1000
Number of CPUs : 2
Operating System : OS 10.2.4
Rendering (Single CPU): 94 CB-CPU (279 Seconds)
Rendering (Multiple CPU): 162 CB-CPU (160 Seconds)
Multiprocessor Speedup: 1.72
[ March 31, 2003, 10:25 AM: Message edited by: Greg Hess ]
Old March 31st, 2003   #15 (permalink)
STRAT's Avatar
Wales
Greg - what do those render times equate to in seconds? those figures stated in the results dont exactly mean much to me.
STRAT is online now
Old March 31st, 2003   #16 (permalink)
Greg... i am running the same motherboard as you (ECS K75SA)on my home computer. my cpu is a athlon thunderbird 1.4ghz. the processor and the motherboard both support a 266 front side bus, but when i change the setting for the motherboard in the bios to 266 my machine will not boot. it booted once for about two minutes with this setting, then crashed. instead i have to run at a 200 front side bus, which knocks my processor down to 1ghz speed wise. i tried contacting ecs about the problem several times (both phone and email), but they have the worse support i have used. i bought the board when it first came out, and i have not tried to flash the bios with an update. i don't want to try that, unless i know it will work. anyway, i was wondering if you had a similar problem, or if yours worked correctly straight out of the box. i know several people on their web board were complaining of a similar problem. i am not to worried about it, since it was only a $60 board, but it would be nice if it worked correctly.
any advice?
ts.
travis schmiesing
Old March 31st, 2003   #17 (permalink)
thanks greg.
if memory serves, i am running 2 256 meg sticks of Crucial pc2100. i contacted crucial when i first had the problem, and according to them the ram should run 266 without a problem. of course that was tech support over a phone.
i will try taking a stick out tonight and see if that helps.
travis schmiesing
Old March 31st, 2003   #18 (permalink)
STRAT's Avatar
Wales
Originally posted by Greg Hess:
I'll rerender to get seconds. Re rendered and added seconds. Also moved crazy's post to the hardware section.
Ah well that didn't work...so strat when u get a chance, move his post to the technical/hardware section please.
which post? gimme URL
STRAT is online now
Old March 31st, 2003   #19 (permalink)
Greg Hess's Avatar
CINEBENCH 2003 v1
Tester : G-tastic
Processor : Athlon 2400+ XP
MHz : 2000
Number of CPUs : 1
Mboard: Asus A7N8X (The Nforce2 One)
Mem: 512 PC3200 Corsair XMS (Not DC-DDR)
Rendering (Single CPU): 240 CB-CPU (109.5 Seconds)
Old March 31st, 2003   #20 (permalink)
Greg Hess's Avatar
CINEBENCH 2003 v1
Tester : G-man
Processor : Athlon 2200+ XP
MHz : 1800
Number of CPUs : 1
Mboard: Nforce2
Ram: 512 Mushkin PC3200 DDR
Rendering (Single CPU): 217 CB-CPU (121.3 Seconds)
