Name: Stephen Leworthy |
hi cga'ers
orininally posted in the cinema 4d forum, but i thought why not in the general forum? it's Maxon's rendering/graphics card bench tester. why not down load it and pit your computer's whits against the rest? you dont need cinema 4d to use it, (well im almost sure, so i've been told) just down load it, start it up and press START you can download it here - http://www.maxon.net/index_e.html just one more thing, can you also post up the scene render times in seconds too, only it makes life easier [ March 29, 2003, 09:27 AM: Message edited by: STRAT ] |
Name: Paul Griger |
Date 3/3/03 CINEBENCH 2003 v1
************************************************** ** Tester : Paul Griger Processor : Dual AMD 2000+ MP MHz : 1.67 Number of CPUs : 2 Ram : 1G Operating System : Win 2K SP2 Graphics Card : Nvidia GeForce 4 Ti4600 bios: 4.25.00.27.32 Resolution : <1280 x 1024> Color Depth : <32bit> ************************************************** Rendering (Single CPU): 209 CB-CPU Rendering (Multiple CPU): 389 CB-CPU Multiprocessor Speedup: 1.86 Shading (CINEMA 4D) : 214 CB-GFX Shading (OpenGL Software Lighting) : 897 CB-GFX Shading (OpenGL Hardware Lighting) : 1272 CB-GFX OpenGL Speedup: 5.94 ************************************************** ** I await my humiliation from your new system Strat BTW, the CG Talk group posted their tests here: http://www.cgtalk.com/showthread.php...5&pagenumber=1 best, paul
When I was a kid I used to pray every night for a new bicycle. Then I realized God doesn’t work that way, so I stole one and prayed for forgiveness. - Emo Philips |
Name: Jack Bransfield |
Hi Strat,
Here's my setup: Power Mac G4 Dual 1 GHz ("mirrored drive doors") 768 MB RAM ATI Radeon 9000 Pro OS X 10.2.4 and my results... C4D shading: 121 OpenGL software shading: 322 OpenGL Hardware shading: 484 OpenGL factor: 4.00 Raytrace (single CPU): 96 Raytrace (dual CPU): 174 dual speedup factor: 1.81 I just got my copy of C4D about 2 weeks ago, and I'm really liking it. Your radiosity tips have helped too. I'll start posting images in the next couple of weeks for some critiques. Jack
Built Light |
guys, can we also put the rendering scene time in minutes and seconds too? only the values given i dont understand, they're certainly not in seconds.
[edit] Paul, why not change ur resolution from 1280x1024 over to 1280x960? only this will give you a 1.333 ratio renders come out at. [edit] |
#5 (permalink) | ||
Name: Paul Griger |
Maybe it Gigawatts? "1.21 GIGAWATTS!!!" Quote:
As Strat has suggested, this new measurement in Cinebench is a little confusing. I've been using Cinebench for several years on many machines and had developed a very good sense of estimation with it. P3s and P4s were approx Ghz X 10. G3s and G4s were Ghz X 13. The new scale throws everything off. Its a little less than 10 X in raytracing though vs the older versions. This shouldnt be the case since the new engine is 20% fatser. My dual Athlon scores around 36 on the old scale and around 350 on the new scale. Oh well, I guess we just have to get used to the new measurements.
Oh yeah, the UPS guy tried to deliver V8 today so I should have it tomorrow |
CINEBENCH 2003 v1
************************************************** Tester : Steve Leworthy Processor : IBM Intelli Station MHz : 2.66 Xeon Number of CPUs : 2 Operating System : XP Pro Graphics Card : nvidia quadro4 Resolution : 1280x960 Color Depth : 32 bit ************************************************** Rendering (Single CPU): 267 CB-CPU - 1 min 38 secs Rendering (Multiple CPU): 572 CB-CPU - 46 secs Multiprocessor Speedup: 2.16 Shading (CINEMA 4D) : 273 CB-GFX Shading (OpenGL Software Lighting) : 1167 CB-GFX Shading (OpenGL Hardware Lighting) : 1210 CB-GFX OpenGL Speedup: 4.44 ************************************************** [ March 28, 2003, 07:50 AM: Message edited by: STRAT ] |
common guys, any more for any more? you dont have to own cinema 4d to run the tests
btw paul and jack, is it possible you can edit in those render times in mins and secs too please to make life easier? |
CINEBENCH 2003 v1
************************************************** ** Tester : Michiel Quist Processor : P4 DELL MHz : 1700 Number of CPUs : 1 Operating System : Win2K Graphics Card : Nvidia GeForce2 MX Resolution : 1280*1024 Color Depth : 32bit ************************************************** ** Rendering (Single CPU): 147 CB-CPU 170 secs Rendering (Multiple CPU): --- CB-CPU Shading (CINEMA 4D) : 160 CB-GFX Shading (OpenGL Software Lighting) : 674 CB-GFX Shading (OpenGL Hardware Lighting) : 693 CB-GFX OpenGL Speedup: 4.34 ************************************************** ** |
