Autodesk VIZ Autodesk VIZ
Old June 20th, 2005   #1 (permalink)
1eo
Default How do I import from Arch. Desktop to VIZ?
Greetings,
I'm really sorry for asking such a newbee question, but I have never work with neither program.
What format should I use to export from Architectural Desktop? (3ds?)
And how do I import the files to VIZ??? I don't see any option that says import and if I use open... it will not open my .3ds file!!??
V. 2006
Thanks a lot
regards,
Leonardo
1eo is offline
Old June 20th, 2005   #2 (permalink)
1eo
Default Re: How do I import from Arch. Desktop to VIZ?
BTW, is VIZ and VIZ Render two different things? I have VIZ Render 2006
1eo is offline
Old June 20th, 2005   #3 (permalink)
1eo
I think got it! Link to "VIZ Render" does the trick!
However, Is VIZ render a light version of VIZ? I think I'm missing a lot of little options that I rember seeing in MAX or a version of VIZ that I saw once at a friends house?
Is it possible to install the Maxwell plugging in it? (I do know maxwell)
Regards,
Leo
1eo is offline
Old June 20th, 2005   #4 (permalink)
abicalho's Avatar
Hello Leo,
VIZ reads and writes DWG natively. If you do a search for Architectural Desktop or DWG in the VIZ Help you'll find your answer promptly with a ton of options explaining what, how and where to do it.
VIZ Render does not have Maxwell.
Alex Bicalho
abicalho is offline
Old June 28th, 2005   #5 (permalink)
Timothy Saunders's Avatar
viz render is a way way way scaled down version of viz and really sucks to render with. i f you are really wanting to import the model into viz (actual viz) just open up viz, click file, import and find the file and select the layers. you don't want to import the whole thing because desktop creates a billion layers, and it may crash viz. just import what you need. go to perspective view and it should all be there.
Timothy Saunders is offline
Old July 14th, 2005   #6 (permalink)
Another option is to use the file link manager function found under 'file'. If my understanding is correct, it is a much beter way of importing from auto cad. Somtimes information gets lost if you use the import function. Within the File Link manager you can choose to group your objects in a variety of ways; by layer, entity, etc.
Aggie'07 is offline
Old July 15th, 2005   #7 (permalink)
RAYMOND's Avatar
yes agree with file link in viz...
i model everything in ADT... and it links into viz great...
there are a host of setting that give you a lot of control
the only thing I import are Onyx trees
have vizrender but don't use it... once you use Viz you don't want to go back
Viz also is scale down of 3dmax.. of which i hope upscale to.
RAYMOND is offline
Old July 15th, 2005   #8 (permalink)
Name: Jose' de Castro
British Virgin Islands
I agree, file linking to Autodesk VIZ (not VIZrender) works really well for me. I tried VIZrender once and was very disappointed.
Island J is offline
Old July 16th, 2005   #9 (permalink)
ecastillor's Avatar
Mexico
this is the way to go....specially if the project is due to suffer changes....you change in acad...and just hit reload, and the changes are there....it keeps materials, uv mappings, etc etc
ecastillor is offline
Import issues Ravendark 3ds Max 2 January 11th, 2005 07:23 AM
ARCHEVER - world's finest arch visualizations PanzerG General Discussions 10 November 9th, 2004 04:38 AM
Architectural Desktop Performance Issues Aspiring Visualizer! AutoCAD/AutoCAD Architecture 3 October 20th, 2004 03:46 PM
Toolbar differences in ACAD and Desktop sky AutoCAD/AutoCAD Architecture 1 August 24th, 2004 01:02 AM
Arch Desktop Output mbr General Discussions 3 January 22nd, 2003 01:03 AM
