Old June 20th, 2005   #1 (permalink)
ecastillor's Avatar
Mexico
Default Whats your average rendering time in vray interiors?
My interiors in vray tend to be on the slow side....
Especially if i have the knick knacks like Blury refs, displacement, refractions, fresnel refs,vray lights,area shadows,hdri, etc...
In exteriors, vray cuts trhough renders like butter, but the interiors take about 4, 5, 6 hours or more to get a decent resolution.
Is this normal?
How can i seepd up interiors?
lightscape used to take no more than one hour for the same kind of images, but is way too obsolete now..
ecastillor is offline
Old June 20th, 2005   #2 (permalink)
Default Re: Whats your average rendering time in vray interiors?
If I can bring it down to 1 hour per frame, I'm happy. There are things you can do to speed it up without killing the quality. Though I have a small render farm, without that I would be toast.
andrius is offline
Old June 20th, 2005   #3 (permalink)
Sawyer's Avatar
I am working on one image and its 4 hours. I have a lot of stainless and I have glossy reflections on them. What I have works but I may try to work backwards to lower the settings till they look bad. I never know if the settings I have are too high and could be optimized.
Sawyer is offline
Old June 20th, 2005   #4 (permalink)
Well, if you run a low resolution prepass, save out the IR map and then run a full pass along with a seperate pass with no GI - only complete specularity for a reflection pass, you can keep frame times down.
John Dollus is offline
Old June 20th, 2005   #5 (permalink)
well, I guess the question that really needs asking is: "is this an animation or still???" For a high rez still 4,5 or 6 hours isn't too bad. I've had some stills render for 40 hours, of course they are like 10,000 pixels wide and such... For an animation I always render out the irradiance map first. Saves a TON of time.
andrius is offline
Old June 20th, 2005   #6 (permalink)
Sawyer's Avatar
John, Can you give a more in depth example of doing this?
Sawyer is offline
Old June 21st, 2005   #7 (permalink)
archkre's Avatar
Argentina
Is this normal?
But on the other hand with Exteriors you spend many hours doing the environment, so there you have the compensation with Interiors!!
'Back in the young fatherland'
archkre is offline
Vray - Proxy objects and Distrubted Rendering? JamesTaylor VRay Render 18 November 24th, 2008 12:25 PM
Test your PC rendering speed with Vray!!! kris Hardware and Technical Discusions 14 April 27th, 2007 10:28 AM
vray lighting / rendering issue mike_sul General Discussions 3 December 14th, 2004 06:01 AM
First Time Night Rendering Diver Finished Work 1 December 13th, 2004 10:10 PM
Massive rendering time....am I doing something wrong Apropos General Discussions 15 October 1st, 2004 08:26 AM
