3ds Max Autodesk 3ds Max
Old June 22nd, 2005   #1 (permalink)
carlangas's Avatar
Mexico
Default max viewport question
Hi all,
When you set up a scene you have default lighting (if thats what its called), the moment you add a light the viewport changes to reflect the lights in your scene. how can I change that so that I can allways see everything in the scene when shaded regardless of the lights I add? I am using radiosity in my scene and when i shade the viewport it some parts look tool dark and cant see all objects.
thanks
Pleasure in the job puts perfection in the work.
carlangas is offline
Old June 22nd, 2005   #2 (permalink)
Victor Erthal's Avatar
Default Re: max viewport question
you can use "ctrl + L" and quickly change from one to another
Victor Erthal is offline
Old June 22nd, 2005   #3 (permalink)
Sawyer's Avatar
Go to the environment window and change the level spinner (default 1) this will change the brightness of the shaded viewport. Does that make sense?
Sawyer is offline
Old June 22nd, 2005   #4 (permalink)
carlangas's Avatar
Mexico
Thanks Victor...
Old June 22nd, 2005   #5 (permalink)
carlangas's Avatar
Mexico
ohh, I didnt see your post Sawyer. does this affect the rendered image as well??
Old June 22nd, 2005   #6 (permalink)
Sorry to disagree, Sawyer. That will increase the ambient light in the scene and as we say in our office: ALVB!!! (ambient light very bad) It'll flatten out the render. Ctrl L is the way to do it. ( or right click on the vewport name, choose configure viewports, then check default lighting. Choose between 1 or 2 lights)
kaylmyers is offline
Old June 23rd, 2005   #7 (permalink)
Sawyer's Avatar
Carlos,
I was wrong. I use vray and it does not affect anything in the rendering. CTRL +L is the way to go.
Sawyer is offline
Question to 3ds max users. Pablo Zurita 3ds Max 0 May 27th, 2005 01:30 PM
3ds max file linker question skippy 3ds Max 4 January 17th, 2005 11:02 AM
3ds max 7 - viewport problem VCRUPI 3ds Max 2 November 18th, 2004 07:36 AM
i have a question...regarding 3ds max 6.0 digibreakthe1st Hardware and Technical Discusions 1 September 16th, 2004 07:18 PM
wysiwyg max materials in viewport...? archkre 3ds Max 5 August 19th, 2003 04:12 AM
