3ds Max Autodesk 3ds Max
Old June 23rd, 2005   #1 (permalink)
Banned
  Send a message via AIM to haneet khanna
Default animation is coming very jaggy
hello everyone
i am rendering an animation with scanline renderer
i am saving the files as tga sequence of images.
the tga is set to 24 bit.
yhe problem is that i am getting very jaggy animation when i output my tga's as avi using the ram player of max.
what can be the problem..
i have use tiles map of max as material at various places ..the mortar joints or lines are also very jaggy
please tell me that what can be the problem
image size i am using for tgas are 720 x 576.
is it fine and frame rate is 25 fps is thi salso ok?
please help ASAP
thanks
haneet
haneet khanna is offline
Old June 23rd, 2005   #2 (permalink)
Default Re: animation is coming very jaggy
try and post a sample
JamesTaylor is offline
Old June 23rd, 2005   #3 (permalink)
Banned
ok here is a small clip of what i am talking about
u will need the xvid codec to run the animation
thanks
www.geocities.com/haneet22/jaggy.zip
Old June 23rd, 2005   #4 (permalink)
STRAT's Avatar
Wales
i cant even open the zip file. it says file corrupt.
there's nothing wrong with the size and frame rate you say, but by the sounds of it your processor cant keep up with the frame rate.
STRAT is offline
Old June 23rd, 2005   #5 (permalink)
Banned
i have attached the avi file now...
please check it
www.geocities.com/haneet22/jaggy.avi
strat
my processor is p4 3.0ghz and 2gb ram . i think my processor is not that slow...that means that if my client plays this on his comp who doesn't have such a strong system then it will come jaggy there..whats the solution for this..
thanks
Old June 23rd, 2005   #6 (permalink)
STRAT's Avatar
Wales
that link is dead
STRAT is offline
Old June 23rd, 2005   #7 (permalink)
Banned
i think the avi attachment is also not working please tell me where can i upload my file
thanks
Old June 24th, 2005   #8 (permalink)
Croatia
i had the same problem with ram player...then i tried using the video post and it works great...try it
amarkovi is offline
Old July 1st, 2005   #9 (permalink)
Romania
hmmm
you are using a bad codec settings to compress the animation.... try to save it uncompressed. i'll have a lot more quality....
samov is offline
Old July 8th, 2005   #10 (permalink)
Banned
here is another link to the clip
hope this one works
www.geocities.com/haneet22/anim.zip
or this link http://us.share.geocities.com/haneet22/anim.zip
please reply soon..its urgent
another thing i would like to tell u regrading this clip is that i have used catmull rom filter and fps is 30. codec used is xvid.so u need XVid Codec to run this anim. even if i make an uncompressed avi using the ram player i face the same problem
plz help/....
thanks
What is the best setting for animation using VRAY? cxdesigner VRay Render 2 July 13th, 2005 01:14 AM
Any experience in real scene modeling for an architecture animation? rabbitrong General Discussions 0 March 30th, 2005 11:23 PM
irradiance for animation crazy homeless guy VRay Render 27 August 17th, 2004 05:42 AM
executive wing animation crazy homeless guy Work in Progress (WIP) 30 June 21st, 2004 03:20 PM
animation converter for LS from MAX ??? dombi Lightscape 8 May 26th, 2004 05:37 AM
