| 3ds Max Autodesk 3ds Max |
Name: Edward samawi |
hello all
i've imported a dwg file to max but whenever i try to import / merge another model it doesn't appear in the viewport or layers though i can move it ! also if i try to create a box from max it also doesn't appear tho i can see its parameters in the modify panel ..any help to fix this will be appreciated.. & here is a screenshot of the problem.. ![]() |
thanx for your reply...but i checked it ..all layers are visible & non of them are on freeze am afraid i have to re-install max
Name: Alex Bicalho |
2 whats? You don't have a Display Unit, to it's impossible to compare that with the size of the house.
It could be 2mm, which then would be perfectly right. |
| importing DWG in 3ds max | jasonlg3d | 3ds Max | 9 | May 28th, 2005 12:21 PM |
| 3ds max file linker question | skippy | 3ds Max | 4 | January 17th, 2005 11:02 AM |
| AUTOCAD dwg file convert to PDF file | Chris Potts | AutoCAD/AutoCAD Architecture | 9 | October 8th, 2004 01:42 AM |
| importing a cad dwg to 3d max 4 | grooveulas | 3ds Max | 6 | September 19th, 2004 07:46 AM |
| File Link DWG in max5.1 | fatNjazzy | 3ds Max | 6 | June 18th, 2004 10:14 AM |
