Name: salf none |
I have a problem with the XREF or IMPORT function on 3ds MAX.
For example, im making a room, and then i want to add some furniture I downloaded from internet, when I XREF those objects into my scene and close the file, and open it again, the XREF objetcs are missing.......why?...i didnt moved the root folder or the files, but for some reason it doesnt show up on the scene, just a lot of "X"s instead of the models. I think it does the same if i import/merge the furniture instead of XREFering, am i doing something wrong? |
I don't have a clue on your problem, but like to add one.
When I merge an object or xref/merge the same object (from a bought collection) the same object enters the scene in two different scales... Any one got a clue on this? nisus |
#4 (permalink) | |
Name: salf none |
Its pretty strange, in the current scene im working on, Id XREF 2 objetces from 2 files, 1 its a kitchen model and the second its a sofa, i set my objetcs, render, and save and close the file, when i opened it again, when loading the file, 3dmax tells me it cannot find the sofa objects (like if i moved or changed the root folder, but i didnt), funny thing is that the kitchen is there but the sofa isnt (just a bunch of "X's") So maybe its a problem not with the XREF, but with the file source, i got it from internet, maybe its saved in a way you cannot XREF it (which i dont think) or the way the objects are grouped, dunno......or maybe a scale issue? |
The Xs generally mean Max can't find it. If you haven't specified the path in 'configure paths', it's a gamble whether it will find xrefs when reloading a file.
If you go to configure paths, choose the xref tab and add the path to your xrefs, it should work next time you load the file. It's certainly worth giving it a go. It won't delete the path to max/scenes you've already got in there. |
| Merge question | danteprojetos | 3ds Max | 2 | March 28th, 2005 12:08 PM |
| Removing missing XREF Objects | bwilson | 3ds Max | 0 | November 2nd, 2004 02:25 PM |
| Missing Maps on Merge | mbr | 3ds Max | 2 | October 8th, 2004 06:54 AM |
| "Xref object" won't recognize new geometry after I xref object | RTurner | Autodesk VIZ | 0 | August 26th, 2004 12:19 PM |
| dual CPU issue | Beno | Hardware and Technical Discusions | 3 | April 6th, 2004 07:58 AM |
