Autodesk VIZ Autodesk VIZ
Old June 23rd, 2005   #1 (permalink)
Default Animation & Automatic Exposure
I'm wondering if there is any possible way in Viz to create an animation using Automatic exposure?! (with no raytrace/ fancy lighting) instead of the typical Logarithmic exposure?
Are there any automatic settings that I can revise so that it doesn't flicker??????!
I had originally created a bunch of Images of 3 office towers using automatic, and I am now creating an animation. It looks great except for the flickering! I've tried it with logarithmic and it well...looks like crap! very faded and boring, not shiny and kinda realistic like it does with Automatic however it solves the flickering problem!
Any advice is greatly appreciated!!! Thanks
Aspiring Visualizer! is offline
Old June 23rd, 2005   #2 (permalink)
abicalho's Avatar
Default Re: Animation & Automatic Exposure
Cheryl,
No, the help specifically says it's not supported. Automatic works by sampling each and every frame, thus creating the flickering.
Alex Bicalho
abicalho is offline
Old June 27th, 2005   #3 (permalink)
AJLynn's Avatar
Automatic exposure doesn't really work with... anything. And it messes up your levels. I used to use it because it's so nice and easy, but I don't think it's worth it - you can get better results by working with the lighting.
AJLynn is offline
What is the best setting for animation using VRAY? cxdesigner VRay Render 2 July 13th, 2005 01:14 AM
executive suite animation crazy homeless guy Finished Work 10 September 3rd, 2004 06:23 AM
irradiance for animation crazy homeless guy VRay Render 27 August 17th, 2004 05:42 AM
executive wing animation crazy homeless guy Work in Progress (WIP) 30 June 21st, 2004 03:20 PM
animation converter for LS from MAX ??? dombi Lightscape 8 May 26th, 2004 05:37 AM
