Old June 23rd, 2005   #1 (permalink)
Name: Tom Bosschaert
Default My 3 last Interiors - Lightwave, Fprime & Lightscape
Hi guys,
I thought I'd share my 3 last interiors.
Rendered with Lightwave, Fprime and Lightscape. I dare you to guess which one is which : )
All on 3500x2480 (A4@300 dpi) for clients. The objects are mostly shared between scenes. Complete setups made in one day from scratch to halfway through the final render at least. Max rendertime for one was 14 hours at the given resolution.
Cheers!
Simple. Good. Except.
http://www.except.nl
exception is offline
Old June 23rd, 2005   #2 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
Default Re: My 3 last Interiors - Lightwave, Fprime & Lightscape
Dang, you're good!
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Old June 23rd, 2005   #3 (permalink)
jucaro's Avatar
Name: Juan Carlos Rosalejos
Philippines  Send a message via Yahoo to jucaro
here's my try,
F-Prime, LS, LW
So, which one is which?
jucaro is offline
Old June 23rd, 2005   #4 (permalink)
Tim Nelson's Avatar
I don't really know the different renderers that well, but I will guess.
1)fprime 2)lightscape 3)lightwave
The third one is gorgeous.
Tim Nelson
timnelson3d.com
Tim Nelson is offline
Old June 23rd, 2005   #5 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
i second the third.
crazy homeless guy is offline
Old June 23rd, 2005   #6 (permalink)
Marko_JJ's Avatar
Canada  Send a message via AIM to Marko_JJ Send a message via MSN to Marko_JJ
Yeh the third is a beauty.. in the first one the TV looks abit odd.
Marko_JJ is offline
Old June 23rd, 2005   #7 (permalink)
the first 2 are blown out to much. ......more than the third one is. in the second image, it is blown out to the point where you can not see the light or even hole for a light on the ceiling. you just see a bright spot. that bright spot makes it feel like poor scanline rendering where a light source is to close to a surface. maybe if you can down the overbright in the first to images, they would match the quality of the third.
also, the view in the second image is a forced cg view. it doesn't feel good (imo).
Old June 24th, 2005   #8 (permalink)
Yeah homeless guy you are very right.... The client wanted the full room in view so its a rediculously large lens angle without distortion. Makes it strange.
Image 3 clearly received most attention, Image 1 is still in processing.
Image 2 is the LightScape one. Image 1 and 3 both have been rendered with Lightwave and Fprime. Yeas I cheated... : )
I totally agree on the blown out ceiling lights part... But since that was the first, and I spent most attention on 3, I feel I'm getting the hang of it : )
I will redo 1 to lessen the blowouts.
Lightscape Scripts for max molson Scripts 10 July 25th, 2008 06:39 AM
Lightscape into LW v8 tutorial exception Lightwave 1 February 8th, 2005 04:37 AM
Lightscape to Lightwave v8 tutorial exception Lightscape 7 February 7th, 2005 07:47 PM
3.2 Lightwave plugin... exception Lightscape 1 July 31st, 2003 06:40 AM
lightscape to be retired stephen gilbert Lightscape 14 December 22nd, 2002 11:11 AM
