Old June 27th, 2005   #11 (permalink)
Denmark
Default Re: Making Grass
Hallo again!
Hey that displacement isn't that stupid. I've been playing with it the last few hours and have got some ok results. They aren't perfect yet, fare from actually, but I'll get there.
here's the tutorial I used. if anyone's interested I could try to post the result (if I ever get one).
http://www.x-opher.com/3d-rendering/lawn-tutorial/
nhj84 is offline
Old June 27th, 2005   #12 (permalink)
Denmark
Think I've got it guys. Changed some settings and got myself another texture map (quite important ). Only problem now is that it doesn't look random enough
nhj84 is offline
Old June 27th, 2005   #13 (permalink)
Kuwait
Hi ecastillor,
I am using MAX 7
can u help ?
TRUSTYGUY is offline
Old June 28th, 2005   #14 (permalink)
Tommy L's Avatar
Im trying to make some decent grass with vray. This is the best ive managed. Anyone got any pointers/tutorials/settings advice?
Cheers all.
Tom.
Tommy L is offline
Old June 28th, 2005   #15 (permalink)
Thumbs up Re: Making Grass
nhj84, clould you post your settings?. Where did you find the other texture map?
skauty is offline
Old June 29th, 2005   #16 (permalink)
Denmark
Hey. I'll post my setting and a render i a day or two. Haven't had time to finish up, which kind og sucks. I have som problems with some bump maps, on a wooden deck so....
nhj84 is offline
Old June 30th, 2005   #17 (permalink)
Sweden
Tommy L - I get almost the exact same look with my Vray grass.... it looks OK, but not great. I think you need to scale down your UVW-mapping so the grass-strands get much thinner...
If you only need to put grass on a small surface then Vray Fur looks great... but if you fill a lawn with that stuff its gonna render forever....
skogskalle is offline
Could someone show me realistic flat mapped grass? MegaPixel Autodesk VIZ 4 October 6th, 2006 06:19 AM
Flat mapped Grass Options? MegaPixel 3ds Max 3 April 2nd, 2005 05:47 PM
Freelancers wanted at Green Grass Studios in Dallas! sandpiper Job Board 1 February 3rd, 2005 08:07 AM
Procedure mapping for grass Saturn Autodesk VIZ 2 August 11th, 2004 03:48 AM
Rendering grass in 3D Max Brian Cassil Tips, Techniques and Frequently Asked Questions 39 August 2nd, 2003 10:33 AM
