Name: Shay Gaghe |
Hi,
I is the best software for doing interior design and planning. I need something that include all the components like door ,windows furniture and so on. And I need it to be capable to export a clean model for Max. (Please dont offer SketchUp) Thanks Shay |
#2 (permalink) | |
Name: Stephen Leworthy |
other than that, any CAD application will do. although you'll have to search out objects like couches and other furnishings. |
Name: Markus Byron |
FormZ is much more accurate, or easier to be accurate, than most 3D packages. It's the best modeler fro arch that I've used.
But anything will do. |
Name: Shay Gaghe |
Hi,
I’m using SketchUp to make the whole model including interior and exterior walls, door and windows inside SketchUp and than export DXF of it to MAX. I have some problems regarding to the thickness of the walls. I used to draw a rectangle and use the offset tool to achieve some thickness before extruding, but if I want to apply a window or a door to two layered wall it will make a hole in the glued wall while leaving the other layer solid. Without using two layered walls everything is ok but when exporting it to Max everything is mess Thanks Shay |
| About time | garethace | Hardware and Technical Discusions | 19 | September 12th, 2007 08:33 AM |
| Software forum? I need some software... | Cesar R | General Discussions | 3 | October 27th, 2004 06:45 AM |
| Does PC have the best software? | Cesar R | Hardware and Technical Discusions | 5 | June 23rd, 2004 10:17 AM |
| Digital asset management software beta test | PhillipT | General Discussions | 13 | October 13th, 2003 08:30 AM |
| software | Luigi ascione | Lightscape | 7 | March 11th, 2003 11:37 AM |
