Old March 30th, 2003   #1 (permalink)
miguelafi's Avatar
Mexico  Send a message via MSN to miguelafi
Unhappy
i have a small rendering network of 4 pcs, but i can process a heavy animation with network rendering in viz 4 im having problems when the machines try to write each part in a common directory, using a local unit in each machine works pretty fine, but they are separate videos and every one is incomplete, thanks if anyone can help me with this
sorry for my english.
gracias
Miguel Angel Flores Izquierdo
Arquitectura y Representacion en 3D
www.ar3d.net
miguelafi is offline
Old March 30th, 2003   #2 (permalink)
quizzy's Avatar
do not render to .avi or .mov but to seperate images (jpg or something else) that should do it. Render them in some other program to one movie file.
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old March 30th, 2003   #3 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
Do not render to jpg files, as those will have compression, and then when you complie the animation in Premiere or whatever, you will be adding a new compression on top of it.
Render to TIF, if you can. The files will take up a lot of disk space, so be sure you have the HD space available before rendering.
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Old April 1st, 2003   #4 (permalink)
quizzy's Avatar
you can render to jpg. Let me explain:
If you would render a 640x480 res sequence at 25 fps. If you would render one jpg, how much Kbyte would one jpg be? Well, 100 - 200 Kbytes (depend on the amount of color and compression. I would suggest that you go for maximum quality for the jpg-files. How much Kbyte would this be per second animation? 25 * 200 Kb = 5 MB. Believe me, your final animation for web or cd-rom will not be 5 MB per second.. So if you don't have much hard drive space just render to jpg's, you won't see the compression degradation in your animations due to the use of jpg's. The final compression codec however is going to determine your final quality (wich will be allways worse than the jpg')
If you are rendering for television or film, its a whole different story. Then you should render top quality uncompressed images..
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old April 1st, 2003   #5 (permalink)
Germany
As mentioned before the best way is to render single images, like tif or tga. So you can easily put those image sequences together at do the usual compositing and cutting, and compression is of course the last thing you do before you send out the animation file.
HTH
ingO
ingo
www.im-graphics.com
ingo is offline
Old April 2nd, 2003   #6 (permalink)
Brian Cassil's Avatar
I agree with ernest and ingo. Hard drive space is cheap these days anyway.
"writing notes is quieter."
Brian Cassil is offline
