3ds Max Autodesk 3ds Max
Old June 30th, 2005   #1 (permalink)
Question Displacement Problem
Greetings,
I am trying to render some areas of turf with a displacement map added to the material (using MentalRay) and the direction of the displacement is going in the opposite direction (as illustrated in the image). I need it to go up, towards the sky. The normals on the mesh are correct, so I've run out of ideas? Any suggestions? Thanks
Rusty
rcase is offline
Old June 30th, 2005   #2 (permalink)
ecastillor's Avatar
Mexico
Default Re: Displacement Problem
i dont use mental ray, but try giving the displacement the opposite value that it has now....
If its 20...give it -20......hope it helps.
ecastillor is offline
Old July 1st, 2005   #3 (permalink)
The setting was at 100! So I dropped it down to like 25 and now it looks good. You can't beat Mental Ray's displacement mapping! Thanks.
rcase is offline
Computer Problem? Need Help? Check Here First! Greg Hess Hardware and Technical Discusions 7 August 22nd, 2008 05:38 PM
Vray displacement problem Chad Warner VRay Render 2 December 3rd, 2004 11:07 PM
Displacement problem NeumannHomes General Discussions 5 September 17th, 2004 09:37 AM
MAX6 MR Displacement Shader wda 3ds Max 1 April 7th, 2004 09:46 AM
