Old April 19th, 2006   #5 (permalink)
jntdigital
Default Re: Autodesk VIZ 2006 or Vue 5 Infinite
in Vue with any changes to the design, you have to reimport the model. thats a royal pain. but since 3ds max and Viz still share the same code, maybe you could link you model in viz and use xstream from viz to vue? that seems like alot to go through when you could just use Viz. Vue's ecosystem is really good for handling large amounts of vegetation for your overall masterplan type images. but you really need to have the design finished to keep your sanity.
it has some shaky results, but you can export almost everything out of Vue so you can use it in viz. I use Cinema 4D btw, so your result may be different.
JNT
jntdigital is offline   Reply With Quote
