Originally Posted by AJLynn
....The Autocad compatibility doesn't sound very important to you, and you can get very good results with Cinema's Advanced Render or FinalRender, and there is a Cinema to Vray plugin in the works anyway....
What I don't like about Cinema is that I find it more difficult to get a very realistic render than with Vray.
We just switched to Archicad from Autocad the first of this year. Felt like it was time to switch from a 2D>3D workflow to a 3D>2D flow. Although I've used 2D Acad for years, I was always quite hateful of the Softdesk attempt at 3D, and its migration to ADT has not changed that. After a nightmare learning curve I feel that Archicad has been a very good choice for us.
Seems like if/when the Vray plug-in becomes available for C4D, that there would be very few "cons" left to consider for C4D. I can't find any "announcements" regarding Vray for C4D, can you give me any more info regarding this?
Thank you very much for your help.
