Old July 15th, 2005   #1 (permalink)
Default Alpha texture mapping
I want to reduce geometry in my model.
I have applied texture with alpha chanel, but cannot mapp it corectly. My triangles are making a circle surface that I want to have holes.
Help.
Beeeee!
del82 is offline
Old July 15th, 2005   #2 (permalink)
Norway  Send a message via MSN to tuekappel
Default Re: Alpha texture mapping
i'm sorry, del 82, but you're not making sense.
try explaining again.
OK, now i get it. you need to point out 3 of the corners of the uvw map, but don't snap to vertices. you need to point out the corners of a square circumscribing your circle.
tuekappel is offline
Old July 15th, 2005   #3 (permalink)
stuuuuupid!
I didnt "remembered" that.
Thanx!
Beeeee!
del82 is offline
UVW mapping question. salf 3ds Max 3 July 15th, 2005 01:40 PM
using stored alpha channels ....how? haneet khanna 3ds Max 6 April 11th, 2005 12:15 PM
Mapping a curved road rcase 3ds Max 4 April 10th, 2005 03:16 AM
Mesh to Texture holes in solution exception Lightscape 9 November 12th, 2004 04:06 AM
Texture problem Mental Ray Chucky Maya 2 October 10th, 2003 07:51 PM
