Name: Andrew Willard |
Hey guys,
I'm trying to create a large plane of perforated metal mesh that is a gradient moving from highly perforated on the left hand side to un-perforated on the right. Is there a procedure for creating this type of texture map in Max? its driving me out of my damn mind....and I tried to model it and it ate my computers heart. Thanks for the help |
Name: eduardo castillo |
thats right...I did something like that long ago....i didnt even have to fdraw the circles....just a gradient map.....this could help you
http://home.zonnet.nl/epragt/tutoria.../index.jsp.htm |
Name: Aaron Fredericks |
This is ironic. I am attempting to do the same effect. You can easily create a mask using the gradient ramp. view the screenshot for how to create the mask. Once you create the mask, then use the blend material to blend the desired metal material with a transparent material with the mask defining the areas of metal and transparency. in order to get the varying degrees of perferation, mix another mask that has tighter circles and blend them with a gradient mask. you might want to play with the output of the mixed masks to ensure that you have black and white circles rather than gray circles.
My problem with this method is that I am having trouble getting the materials to work with Mental Ray. Last edited by Aaron; July 18th, 2005 at 05:42 PM. |
| metal paneling and more.... | Timothy Saunders | Work in Progress (WIP) | 7 | July 13th, 2005 11:58 AM |
| Metal Panel Wall :: Diamond/Ellipse Shape | mbr | 3ds Max | 2 | February 23rd, 2005 05:14 PM |
| perforated metal panel | frank_1331 | Autodesk VIZ | 1 | February 9th, 2005 10:50 AM |
| Gradient Banding | nisus | Photoshop | 20 | January 26th, 2005 12:47 PM |
| Beachfront Metal Glass Apartment building. | Archmage | Work in Progress (WIP) | 11 | July 5th, 2004 12:37 AM |
