3ds Max Autodesk 3ds Max
Old July 20th, 2005   #1 (permalink)
Name: ray ray anderson
Default combine object by layer
When I import dwg's into 3dsm I get a dialogue box. If I check 'combine object by layer' I lose some flexibility over some objects. For example, if I put all my walls into a layer and then export to 3ds, all my walls become one object. So if I want to extrude a wall to a certain height all walls get that same height. I can't give each wall a different height, unless I uncheck the 'combine object by layer' box or if I put each wall into a separate layer in AutoCAD before exporting.
Am I doing something wrong or do you just leave the ' combine object by layer' box unchecked?
rayray is offline
Old July 24th, 2005   #2 (permalink)
Jennifer's Avatar
Default Re: combine object by layer
There are times you'll want it checked, and times where you won't. If you leave it on, you can always get to the individual splines or mesh objects through the Modify tab, and the Editable Spline or Editable Mesh. Any object you need to edit individually you can detach from the larger object, then Extrude or modify as needed.
When checkbox is off, the objects will still come in on the Layer defined, but as indivdual pieces. Then you may find you'll have to Attach one object to another to get them to extruse and edit as you need.
Have fun!
Jenni
www.4DA-inc.com
Chicago 3ds Max / Maya UG www.max3ds.com
Render UG www.Render-Art.com
Jennifer is offline
Max6: How to get rid of the prefix 'Layer:' in importing dwg HarryG 3ds Max 0 November 30th, 2003 08:16 PM
Modeling: Selecting single objects on one layer coming from AutoCAD into MAX Jet 3ds Max 4 November 5th, 2003 08:08 AM
Application layer on Sets? nisus Photoshop 10 October 11th, 2003 06:09 AM
NPR version archkre Finished Work 10 January 6th, 2003 11:11 PM
NPR-techniques nisus Tips, Techniques and Frequently Asked Questions 24 January 4th, 2003 12:40 AM
