Go Back   CGarchitect.com > 3D SOFTWARE > SketchUp
SketchUp @ Last Software SketchUp
Old July 20th, 2005   #1 (permalink)
Default Export to EPS
Hey any tips for exporting to EPS?
I'm a new SketchUp user.. I started on Sunday (July17th). This is the first building ive done with this program, just something i came up with. I like the program but the more complex the model the harder i find sketchup to use...
Im finding it takes a very long time to export to EPS. when it finally finishes the stroke pen weight on the lines is very thick, so thick it hides the details. I solve this by scaling in Illustrator without scaling the pen weights but i find that sketchup doesnt properly draw all the details ive modeled in the program. for example if you look at the cornice you'll notice areas that are not outlined. How can i get this to output correctly? I want a vector file, if i wanted a raster i could print the screen.. or export to a jpeg but not what i want.
Am i missing something??
Mike..
ps. this jpeg was created from an eps export so you can see the troubles i have.
bobseasier is offline
Panorama not allowing QTVR export of image MegaPixel 3ds Max 5 September 8th, 2006 06:51 AM
acad solid export from Viz/Max? CRD Autodesk VIZ 1 February 17th, 2005 10:10 AM
Arc+ export 3DS guzmoc General Discussions 0 January 19th, 2005 08:53 AM
Texture export from Max 6 ? Noise 3ds Max 3 June 7th, 2004 02:49 PM
How to export a vrml with LS? ark_d2 Lightscape 2 August 19th, 2003 09:39 PM
