Old July 23rd, 2005   #1 (permalink)
Default Vray displacement problem
I'm having a problem with Vray freezing up, only at certain frames, during a rendering of a roof with a displacement modifier on it.
If I hide the roof, the image renders fine. If I hide everything but the roof or have the roof on the rendering freezes.
If I turn off render displacement on the rendering panel with the roof on the roof will render.
I've tried to merge the file in to a new file, rebuilt the roof and still have the same issue.
The strange thing is it displacement works on all be a few frames on just a select few of the file I have or multiple roofs with the same base map.
Anyone else have this problem or suggestions on how to remedy it?
Dan J is offline
Old July 24th, 2005   #2 (permalink)
jow
Default Re: Vray displacement problem
U could try a vray proxy instead...
jow is offline
site - vray grass / displacement map tutorial Gleggers General Discussions 6 July 13th, 2007 08:10 AM
vray lighting problem Cesar VRay Render 10 November 24th, 2006 12:30 PM
vray problem carlangas VRay Render 5 July 25th, 2005 01:08 PM
Vray displacement problem Chad Warner VRay Render 2 December 3rd, 2004 11:07 PM
Vray Problem <-- weird splotches stylez VRay Render 14 September 4th, 2004 08:58 AM
